Tire size on 07 mega cab daully
Old Jan 23, 2007 | 07:56 PM
Huntsalot's Avatar
Tire size on 07 mega cab dually
Sorry if this is in the wrong section. I am wondering what size tires I can run without wheel spacer. BFG does not make a 235 70 17 . I would like to run the same size or go to 265 if I can. Just have not heard good things about wheel spacers. Thank you all for your help
Old Jan 23, 2007 | 10:09 PM
Huntsalot's Avatar
Wow no one TTT
Old Jan 23, 2007 | 10:13 PM
D.Wiggs's Avatar
265s will work if I remember from some other posts.
Old Jan 23, 2007 | 10:35 PM
Patrolman808's Avatar
I think a guy at work has 285s. Seems like he put a small spacer between the rears b/c he pulls a trailer now and then.
Old Jan 23, 2007 | 10:52 PM
RedRam410's Avatar
[IMG][/IMG]
I had the same problem because i didnt want to get spacers either but i did want a little bit bigger of a tire... these are 265/70/17s and they do really good and i have plenty room between the back tires. you can look at my pictures in my profile! hope this helps!
Old Jan 23, 2007 | 11:08 PM
Huntsalot's Avatar
RedRam how heavy do you tow??
Old Jan 23, 2007 | 11:23 PM
RedRam410's Avatar
not exact on the lbs. but i pull a 24ft gooseneck trailor hauling 6400 and 6300 john deere tractors all the time and 8 6x6 round bales at a time.
Old Jan 23, 2007 | 11:25 PM
RedRam410's Avatar
and with these big loads behind my truck i still have a half inch between the tires
Old Jan 23, 2007 | 11:51 PM
Huntsalot's Avatar
Thank you for your help. I will call some tire shops in the am and see if it will work because I do not want to run spacers
Old Jan 24, 2007 | 07:33 AM
gsbrockman's Avatar
LT265/70R17 Mastercraft Courser C/T's on bigd6.6's 2006 RAM 3500 CTD DRW.
Greg
Old Jan 24, 2007 | 08:56 AM
RedRam410's Avatar
the tire places might say that it wont work because a lot of tire places told me it wouldnt but the guys on the forum said it did so i just said put em on the truck lol and they fit fine
Old Jan 24, 2007 | 06:45 PM
Huntsalot's Avatar
Greg
Are you running spacer in the rear?
Old Jan 24, 2007 | 09:31 PM
HDBeauty's Avatar
I put 265-70/17 on mine also. They are Toyo Open Country AT with NO spacer!
Shayne
td3620
Dec 23, 2013 06:00 AM
td3620
Jul 20, 2011 10:45 PM
jimbo486
13
Nov 5, 2009 09:17 AM
Jan 14, 2003 12:14 AM
26
Nov 7, 2002 06:45 PM
