Tire size on 07 mega cab dually
Sorry if this is in the wrong section. I am wondering what size tires I can run without wheel spacer. BFG does not make a 235 70 17[dummy] . I would like to run the same size or go to 265 if I can. Just have not heard good things about wheel spacers. Thank you all for your help
Wow no one[duhhh] TTT
265s will work if I remember from some other posts.
I think a guy at work has 285s. Seems like he put a small spacer between the rears b/c he pulls a trailer now and then.
[IMG]https://www.dieseltruckresource.com/...ium/tires4.jpg[/IMG]
I had the same problem because i didnt want to get spacers either but i did want a little bit bigger of a tire... these are 265/70/17s and they do really good and i have plenty room between the back tires. you can look at my pictures in my profile! hope this helps! |
RedRam how heavy do you tow??
not exact on the lbs. but i pull a 24ft gooseneck trailor hauling 6400 and 6300 john deere tractors all the time and 8 6x6 round bales at a time.
and with these big loads behind my truck i still have a half inch between the tires
Thank you for your help. I will call some tire shops in the am and see if it will work because I do not want to run spacers
LT265/70R17 Mastercraft Courser C/T's on bigd6.6's 2006 RAM 3500 CTD DRW.
http://kydtr.com/iboard/uploads/av-485.jpg Greg |
the tire places might say that it wont work because a lot of tire places told me it wouldnt but the guys on the forum said it did so i just said put em on the truck lol and they fit fine
Originally Posted by maynard3
(Post 1316897)
http://kydtr.com/iboard/uploads/av-485.jpg Greg Are you running spacer in the rear? |
I put 265-70/17 on mine also. They are Toyo Open Country AT with NO spacer!
Shayne https://www.dieseltruckresource.com/..._The_Front.JPG https://www.dieseltruckresource.com/...s_of_Space.JPG https://www.dieseltruckresource.com/...rom_Behind.JPG |
