Timing/injector Rattle
Old Nov 27, 2007 | 10:28 AM
Super Googan's Avatar
what causes timing rattle and is it bad for the injectors
or motor in any way?
Old Nov 27, 2007 | 05:43 PM
Still hope someone can give me some info on injector rattle
Old Nov 27, 2007 | 06:04 PM
tritont's Avatar
too much timing can be bad. It causes the combustion to happen before it's suppose to which puts a lot of strain on the whole bottom end. I don't know that it's bad for the injectors themselves though.
The timing is control by the ECM and you can't change it other than using a performance box so, if you have a lot of rattle and you aren't using a box... you could check and see if there a flash available for your truck. They have been know to fit rattle and knocking problems.
Old Nov 27, 2007 | 06:15 PM
With the Smarty I get some rattle depending on what level or softwware I'm using. Just want to know if I will do any damage. The truck seems to like the timing for power but if it's bad for the motor or injectors I'll try a another level or software
Old Nov 27, 2007 | 06:20 PM
tritont's Avatar
added timing is what help keep the EGT's down. That's why many are experiencing more rattle than usual with the newest software. The timing has been really increase which is why the EGT's barely get over 1200F.
I no expert by any means but, for everyday driving... you wouldn't want a lot of timing or pressure. If the smarty is making it that bad... yes, you should run a different level.
I had the same problem with rattle on the new software to the extreme but, once I changed to a non timing level, it was 100% better and i still had the power.
Old Nov 27, 2007 | 06:36 PM
Raspy's Avatar
If you think a 3rd gen with a little rattle is bad try listening to a 1st gen or a twelve valve 2nd gen. Way more. No, it's not bad. Diesels are famous for that noise and they've always done it (until the electronic injection and more strict emission rules came along).
I'm glad mine does it because I get the sense that the timing is closer to where it should be.
John
Old Nov 27, 2007 | 06:41 PM
tritont's Avatar
the 3rd gen is a whole other beast from those truck though. That rattle those trucks have was taken out of the 3rd gens with the CR and programming.
Old Nov 27, 2007 | 06:47 PM
Raspy's Avatar
Exactly. But it makes the point that it won't harm the engine. The rattle, whether it's a CR or mechanical is the same thing happening. A very sudden pressure spike upon injection. It seems like it would be damaging, but it's not.
John
38short
Sep 12, 2007 01:23 PM
bsj04
Jul 18, 2007 09:58 PM
timber
May 23, 2007 12:01 PM
timber
May 12, 2007 07:12 AM
