Quad DXZT2 Injector or Timing rattle
Old Sep 12, 2007 | 11:40 AM
38short's Avatar
Just installed Quadzilla DXZT2 tow module. There's some kind of rattle at 2100 rpm., either timing or injector rattle.Is this normal ? Can you run it like that , or will it cause problems
Old Sep 12, 2007 | 12:11 PM
dodgezilla04's Avatar
it is injector rattle caused by slightly higher pressures and the timing advance.. it is normal, but it shouldnt be ungodly loud. if it sounds like a cold 12v, that is abnormal.
Old Sep 12, 2007 | 12:26 PM
38short's Avatar
Thank you for your response. The rattle isn't " ungodly loud" as you described it. There is a rattle as compared to no module . Just wondering if there is a long term effect on the engine. I've been using the lucas fuel treatment for the last 2 months .
Old Sep 12, 2007 | 12:46 PM
you're good to go. no worries. just remember to be gentle until the engine is complelely warm.
Old Sep 12, 2007 | 01:23 PM
omaharam's Avatar
Or even a warmed up 12v.
grecododge
Nov 28, 2009 09:50 AM
bsj04
Jul 18, 2007 09:58 PM
Alpo
Jun 14, 2007 04:59 PM
timber
May 23, 2007 12:01 PM
timber
May 12, 2007 07:12 AM
