For those of you with MagHytec tranny pans
Old Jul 3, 2008 | 06:14 PM
cameroneod's Avatar
Getting ready to install the tranny pan I've had sitting here for two weeks. The pan came with a cork gasket and the new filter came with a rubber gasket. Just wondering which one I should use during the install. Thanks for the help guys.
Old Jul 3, 2008 | 06:32 PM
SS1156's Avatar
I don't have one yet, but I would say rubber gasket. They are not as prone to leaks like the cork gaskets are. This just my experience and my .02.
Old Jul 3, 2008 | 07:34 PM
Seelow's Avatar
Yea the rubber ones are reuseable.
Old Jul 3, 2008 | 07:56 PM
cameroneod's Avatar
No problems with fit on the rubber ones?
Old Jul 3, 2008 | 11:45 PM
username taken's Avatar
Stocker should be reuseable also. Save the others for later or if you run into a leak.
Old Jul 4, 2008 | 12:48 AM
cameroneod's Avatar
Paperwork said not to use the stocker. It was rubber with a stiff core. I used the rubber one that came with the filter and everything looks good. No leaks yet so I'm crossing my fingers. Thanks for the help guys.
Old Jul 4, 2008 | 12:23 PM
poindexter1's Avatar
use the one that came with your mag pan ,mine has been on for over a year NO problems NO leaks great product,you can uncross your fingers now.
Old Jul 5, 2008 | 09:30 AM
zuki_dan's Avatar
My tranny builder put mine on when they built the trans and we reused the stock reuseable gasket and I have had the pan off once after the build and it doesn't leak. I've had bad experiences with cork gaskets even if you torque the bolts properly.
Old Jul 5, 2008 | 09:36 AM
White97GTVert's Avatar
We used the cork gasket. It works well and doesn't leak. Its been off 1 time to change the filter since the trans was installed.
Old Jul 5, 2008 | 09:54 AM
RowJ's Avatar
Rubber gasket from Mag Hy-Tec works very well. Reusing gaslets on a vertical tranny pan is not critical but a new gasket is always best!
RJ
The_Head
Sep 19, 2010 03:10 AM
lowboy18011
May 6, 2007 10:08 AM
lucey
Mar 21, 2006 01:43 PM
KATOOM
May 23, 2003 05:58 AM
SolidJunkMM
18
May 23, 2003 01:55 AM
