Those who are REVO BETA's...
Old Mar 16, 2008 | 07:11 PM
2007 5.9's Avatar
Talking Those who are REVO BETA's...
For the special ones who get to be Beta tester's for the new REVO sw from MADS, can you answer a couple of questions....?
1. With the adjustability of timing with the selection of CATcher SW, stock, after market and #4. Which produces the most smoke output??? I am trying to dial in my truck before we get this DL. I am trying to keep smoke to a min.
2. For stock injectors, what level for RP is considered equal to running a pressure box? (MP-8, X2)
3. Are the TQ MG levels the same as previous versions? I mean, does Wild still require after market trans, and MOD still need light foot for stockers????
I can't wait for this to be released to us, this truly is REVOlutionary and just makes me more proud every day that MADS has made the cummins so competitive in the power world!!!!
THANKS FOR THE WONDERFUL WORK!!!!! MARCO AND BOB!!!!!
Old Mar 16, 2008 | 07:21 PM
jgiachino's Avatar
2 Day's of testing so limited knowledge....level 7 catcher
- Tried #2 and #4...#4 has a haze at light / moderate throttle....#2 does not (but id did cool down some today so that could also be a variable)....on #4, i thought i ate an injector as it hazes pretty good....but great throttle response / power....little too much rattle for me...
- Can say vs pressure box, but #3 is very similiar to beta 4.4 (8k idle, 17k cruising, 25k max)...really want to try #4, but have stock injectors...waiting for AD150 to arrive and may try #4 after better filtration...
- Appear to be the same to me....and yes, wild would need trans mods, esp with the increased power at higher levels....i'd think even on level 1 (100ish hp)
Hope this helps
Old Mar 16, 2008 | 07:31 PM
2007 5.9's Avatar
Sounds good, thanks!!!
Old Mar 16, 2008 | 07:35 PM
JP-4.5's Avatar
What is the reason why Stock injectors cannot run on 4 for pressure? Will it take the tips off of them? #3 sounds like all I want to run with my truck when it comes out I am just an info junky... Need to know why?
Old Mar 16, 2008 | 07:57 PM
2007 5.9's Avatar
I am under the impression that running RP on #4 will lead to cracking stock injectors.
IMO I would not even run #3 without proper filtering to prevent blown injectors...
Old Mar 16, 2008 | 08:01 PM
JP-4.5's Avatar
What are fuel presure for a stock system? I thought under 25k was below the stock pressure limits?
Old Mar 16, 2008 | 08:05 PM
2007 5.9's Avatar
With stock programming RP maxed out @ 23k
With current 4.11 sw I see 23.5-24K
While stacking 4.11 and Quad X2 psi only would see 26.5-27K @ WOT
Anything above 23K is in my mind over stock..I hear that the injectors and rail are good for up to 30K, but without proper filtering they will pop at lower levels.
tennessee
Feb 14, 2009 08:00 PM
wyocat
Nov 30, 2008 11:41 AM
zack birge
20
Jul 11, 2008 10:29 AM
zack birge
Jun 27, 2008 08:35 PM
jrussell
37
May 31, 2007 08:04 PM
