thin air
Old Jul 30, 2012 | 08:58 PM
07nbcowboy06's Avatar
thin air
i have about 4000 ft more then where i was back home and my truck is really sluges(low at the bottom) and smokes really bad. i have adjusted my smarty as much as i can it is a little better what is my next turn?
Old Jul 31, 2012 | 01:01 AM
EDR's Avatar
EDR
I've driven straight through from Vegas to the Colorado high country without an issue. The computer should compensate for the change in altitude and air pressure.
Any other mods to your truck?
Finally, have you checked the air and fuel filters? That's where I would start.
Good luck.
Old Jul 31, 2012 | 08:55 AM
AH64ID's Avatar
Specs on the truck?
What tune?
How much elevation?
Old Jul 31, 2012 | 06:56 PM
sorry guy i thought i was all ready one the i have a tnt revo smarty and 90hp injectore and s&b cold air intack and a 64mm turbo
Old Aug 1, 2012 | 08:09 AM
AH64ID's Avatar
What settings? What elevation?
Help us with all the info so we can help you.
Old Aug 1, 2012 | 07:59 PM
with the turbo thetruck likes it at 7 at 500ft but now i am 4400 ft
Old Aug 1, 2012 | 08:00 PM
AH64ID's Avatar
4400 isn't anything.
What are your other settings?
Old Aug 1, 2012 | 08:31 PM
i had had the timming at defalt that is when it was smoking and laging really bad so i turned it up and it has done better
Old Aug 1, 2012 | 09:05 PM
AH64ID's Avatar
I would try torque management at 1, and timing at 2 on the latest software. If you have the latest software timing 3 may be better.
I would also set PoD to about 90, which shouldn't effect total power just sensitivity.
Old Aug 1, 2012 | 10:31 PM
ok i will have to downlaod the new update then right thank you bud
Old Aug 2, 2012 | 06:32 AM
quadman20's Avatar
AH64ID, I too just went from Phoenix and now live in Colorado elevation went from 1200' to 6500' I to suffer same issue no matter what I try on Jr, also in stock mode it acts the same way. Do you think a more efficent turbo would help with this? Or could it be more involved. I too have replaced all filters to new ones.
Old Aug 2, 2012 | 09:57 AM
AH64ID's Avatar
Not many turbo's will spool quite as fast as the stocker, so I doubt a different turbo would effect it. At 8K my Garrett is like a 1975 freight train if I am not careful.
You already have a modded intake, what about a horn? Maybe a grid delete in summer?
If it does it stock I don't think there is much you can do, short of a UDC tune to pull some duration at lower loads (works well).
Old Aug 2, 2012 | 10:01 PM
quadman20's Avatar
well I'll just wait till UDC is avalible and tune till I likes. Any word on release? I know you got a little in side info.
BigBlue
May 22, 2007 10:42 PM
tfarmer96
15
Apr 20, 2005 04:39 AM
pullin hard
Apr 2, 2005 02:42 PM
Jmac
Jan 15, 2005 06:35 PM
dodgeman01
Jan 14, 2004 02:41 PM
