Studder with 4.2 beta
Old Feb 24, 2008 | 02:43 PM
blwnsmke's Avatar
Loaded the 4.2 beta on my truck a while back. I put my truck in gear and held the brake and got on the gas to do a power brake and it started studdering repeatidly like I had a trans brake or something.. Any ideas?? Truck runs fine only does that when I try power braking..
Old Feb 24, 2008 | 03:11 PM
Bob Wagner's Avatar
the next software release will have the tranny trigger's option to prevent defueling at building boost on the line
Old Feb 24, 2008 | 03:18 PM
blwnsmke's Avatar
So nothing wrong with my truck? Its just the software defueling? What makes it studder like that? How does the computer know when Im trying to powerbrake and when Im just wot going down the road??
Old Feb 24, 2008 | 03:32 PM
highrpms's Avatar
Soon? LOL!
Old Feb 24, 2008 | 03:52 PM
Billm2004's Avatar
i just had the same problem last night when i went out for some testing. I wasnt sure what was going on. it was fine at the track last weekend but last night it did the same thing you are describing.
whats going on?
Old Feb 24, 2008 | 06:33 PM
blwnsmke's Avatar
I dunnooo hopefully bob will chime back in.. Is there another 4.2 coming out??
Old Feb 24, 2008 | 09:28 PM
Billm2004's Avatar
bump for answers..
Old Feb 24, 2008 | 10:54 PM
blwnsmke's Avatar
I think its gotta be in the software if yours does it to.. I can stab the gas from a dead stop no spooling and it will take off and blow the tires up like it should. But if I hold the brake and try to power brake it then it will start that studder like I have a trans brake.. Its pouring smoke but it studders like a trans brake and won't spool and rev hard like you would think would happen if you held brake and mashed the gas.. Besides that just driving down the street and all it seems perfectly fine..
Old Feb 24, 2008 | 11:22 PM
Billm2004's Avatar
yeah, exactly! mine was fine when i took it to the diesel shoot out last weekend, but the other night it did it for the first time. do it happen every time you try to power brake or just now and then. when i felt it, i backed off and then tried again bet easier on the pedal and it seem to be ok. but if i try to power brake and push the throttle too much to fast it does it.
Old Feb 24, 2008 | 11:48 PM
blwnsmke's Avatar
It does it every time I try to power brake.. But runs fine at wot any other time.. Just does it when I power brake
Old Feb 25, 2008 | 07:03 AM
tritont's Avatar
not that this helps but, I've never had that issue using 4.2. IMO, what might be happening is it's over fueling the truck and it's spitting and sputtering... ( like flooding )
4.2 is a heavy fueling program and dumps a ton of fuel right off the bat.
Old Feb 25, 2008 | 09:19 AM
molalla1ton's Avatar
has not happened to me, have done a number of boosted leaves.
Old Feb 25, 2008 | 05:29 PM
blwnsmke's Avatar
Hm well have no idea.. It seems like its in the software because it doesn't run bad or anything when it does it.. Its the same studder repeatidly back to back... And every time it studders it shoots smoke out..
Old Feb 25, 2008 | 05:46 PM
Billm2004's Avatar
i would defin. like to find out what is causing this. Maybe Bob will get back to us?
Old Feb 25, 2008 | 05:57 PM
Bob Wagner's Avatar
no. load up a wild program and try to powerbrake then
