Splicing RECON cab lights?
I just got my RECON cab lights on and I see the problom with them,that cheap 2 wire connection,no wonder they got proploms, anyway has any one cut and direct wired them up yet? I was thinking about doing it.
That or my Petercar had dash lights like that and after using some tinfoil never had a problom with then anymore.
Pav
Pav
save yourself a ton of time in the long run and just hard wire it while you have the headliner down. will only take about 20 more minutes to do it. will be kicking yourself if you don't
Ya,def hard wiring it,
Ooo forgot to ask this,I also installed the 3rd brade light(LED) from RECON,and I have noticed that the cargo light seems to be very dimmly lit all the time,so dim that you have to look close at night to see it,any thoughts on this?
Pav
Pav
Might be faulyt.. .Mine is bright as heck!!! Even after I smoked it!!!
Mine is pretty bright when I have the actual cargo light switch turned on, if the doors are open then the light is dim. I have the bed lights too so I don't worry about the cargo light putting out enough to see anything.
Yes...VERY SOON! Heath is getting a template from Shane, and I am sending him another one with the added markings for a Dakota as well as a Ram.
pipeman90
Mar 29, 2011 09:23 AM
efil4ynot
Aug 13, 2007 10:12 PM
