smarty/tst stack
Old Oct 23, 2006 | 01:44 PM
Agades's Avatar
smarty/tst stack
those running a tst with the smarty
do you still get the 0336 code (caused by tst)
how about the 1100 rpm hikkup?(also caused by tst)
Old Oct 23, 2006 | 02:53 PM
RamWheelsBy4's Avatar
I am running TST, EZ and Smarty. With the right combo I do not have any hikkups or popping out of the stack. Get to high on TST and will experience the popping with mine. Currently I run daily driving TST R49 with 05tt 12* Auto Timing 3/1, EZ on 1 and Smarty SW #4, this seems to be very solid combo. I do occassionaly get a 0336 code with or without the Smarty. Usually only when I get into it before everything warmed up good. Colder the outside temps the more frequent it happens for me.
Old Oct 23, 2006 | 05:10 PM
doug60's Avatar
I'm running Smarty on 1 ,EZ 0n 2, TST on 5/3 no timing.
No codes yet, but the trans is confused.
With the cable adj. to 1/8 I get a 1/2 short shift. Not good!!
With the cable adj. to 3/8 ,I get a 1/2 shift hunt.
Anybody else experiencing this
Old Oct 23, 2006 | 05:27 PM
JCLeary's Avatar
Yes, the hiccup and cam/crank code show up, but only when cold, on the throttle and lugging the truck.
This is a scenario that only happens if I'm really hung over. Since I rarely drink, and more rarely get hung over, and I don't like lugging the truck it almost never happens. When it does happen, it doesn't always throw a code.
Old Oct 23, 2006 | 06:15 PM
WhiteSport600's Avatar
LMAO!!! I noticed that too!
Old Oct 23, 2006 | 06:23 PM
OT-OF-Here's Avatar
I run that stack
An important point was made above and that is for these units to perform like they should you need to be at full operating temp (180*). Having said that these are the settings I can run at wot:
Smarty on SW 9
TST (w/user adj timing) 9/5 @ 3* additional timing
EZ on lvl 3
Also EH 120hp inj. (they gave me LESS smoke)
I used to be the KING of the dreaded pop. The biggest contributor to getting rid of it on my truck was the user adj timing on the TST.
Although I can run the above settings I can't say they will give me the best times in the 1/4 as I haven't run it except on the street but it was a real a.. kicker. I also run the Fluiddamper and F1's cam and springs,... both of which smoooooooothed out my truck at all rpm levels so they probably contributed to getting rid of the popping to some degree.
So the answer to your question is,,........ that stack works NICELY!!
Old Oct 25, 2006 | 07:49 AM
Agades's Avatar
I think some of you are talking about a different "pop"
some are refferring to the popping when you run the rail dry
Im talking about if you hold your truck at 1100 rpm with a tst box installed, you will eventually cause a hikkup and eventually throw the 0336 code.
Ive learned to drive around it but still happens on occasion
and yes it is worse at lower temps, mostly when heater grids cycle
was hoping the smarty would get rid of the problem
Old Oct 25, 2006 | 02:47 PM
Well that is not the senario that sets the 0336 code on mine. It is usually when still not completely up to operating temp and I have to merge on freeway. I get a little to fast and heavy on the throttle. I have never really experienced a hikkup at a constant rpm level and mine I am pretty sure is rail related on heavy throttle with too much TST timing and stacked box levels.
Old Oct 26, 2006 | 09:01 AM
Agades's Avatar
there could be a difference in what sets it between the 555 motor and the 600 motor
other 555 owners I have talked to have experienced the same as I am explaining
Old Oct 26, 2006 | 09:05 AM
Well it seems to me that every truck is different and definitely a big difference between the 555 and 600 trucks. And just when I was bragging about not setting the code(s) normally, set 0336 and 0602 this morning when pulling in the parking lot. No heavy pedal this morning it is raining. I do seem to remember most of my codes set when it is raining. I need to check my connections.
Topper
Mar 3, 2008 10:17 AM
LooseBoltsRob
17
Jun 10, 2007 08:52 PM
smoky beast
28
Oct 13, 2006 01:15 PM
cummnz4x4pwr
Jul 30, 2006 01:37 PM
mjpalmer
May 19, 2005 11:34 AM
