Smarty TNT studdering/poping
Old Jul 10, 2008 | 05:27 AM
torquet's Avatar
I bought a Smarty a couple of weeks ago and love it. Last week I finally got around to uploading the TNT software and now I it studders. If I lug it, it won't do it but if my RPM's are up and I get on the go pedal it stumbles and pops a few times then goes like heck.
I'm not upset, I love the Smarty. Just wondering what is causing it.
Thanks, George
Old Jul 10, 2008 | 06:57 AM
tcr's Avatar
tcr
Sounds like your running out of fuel, either to the rail or to your CP3.
Old Jul 10, 2008 | 07:03 AM
MikeyB's Avatar
Thanks, George
What level are you running at? Sounds like you don't have the supporting mods to run at the higher levels. I started to see issues with the draining rail when going over level 3 on the TNT. The truck would fall flat on it's face.
Either run only on level 1 for the TNT or go to the REVO.
MikeyB
Old Jul 10, 2008 | 08:13 AM
rip 112's Avatar
I couldn't even support the TNT. I had the same issues on TNT, so I just stick to the betas until everything is fine tuned on the Marco side.
Old Jul 10, 2008 | 08:37 AM
soulezoo's Avatar
DTR 1st Sergeant
Looks like he is also working with the old filter housing mounted stock lift pump... that also contributes to the problem at the higher power levels. An arson kit or DIY cp3 mod would also be beneficial to get that "just a little more" fuel that is needed.
Old Jul 10, 2008 | 10:23 AM
torquet's Avatar
Sorry, I forgot to mention I have a Fass95 and a rail pressure guage. The pressures look fine, rail and fuel pressure doesnt drop when it does this.
running level 2 now was on level 4. both on TNT.
I was running the regular smarty program on 9 with out a problem.
I thought I put those mods in my signature. they are now
Thanks George
Old Jul 10, 2008 | 11:28 AM
soulezoo's Avatar
DTR 1st Sergeant
So on sw 2 there is no problem and on sw 4 you have it?
Old Jul 10, 2008 | 02:47 PM
torquet's Avatar
On the TNT version it is doing it on 2 and 4. The only ones I have tried.
Old Jul 10, 2008 | 03:17 PM
tcr's Avatar
tcr
Try level 1, I have issues on every TNT and TNTR tune I've tried and the higher the power level the worse the symptoms.
Old Jul 10, 2008 | 05:42 PM
Mega07's Avatar
Weird...sounds like your draining the rail but you said your pressure is good. Whats funny is that I dont have any fuel mods and I run it on TNT 9 and the truck will do it, but thats usually a run from 0-80, dunno if it will handle all the way thru a 1/4. Its crazy how different each individual truck is when it comes to mods and mpg.
Old Jul 10, 2008 | 09:49 PM
mudder500's Avatar
I put my truck on TNT 9 and it sounded like i had a 2 step launch control leaving the line at the track. It sounded like a honda! Pops like crazy but couldnt figure out why.
-PowerWagon-
Dec 30, 2008 01:06 AM
burf11
Apr 14, 2007 04:33 PM
bigreddiesel
Jan 26, 2007 10:09 PM
twhite
Nov 20, 2005 08:36 AM
