Smarty Timing Rattle
Old Nov 21, 2007 | 11:21 PM
DieselBoy20's Avatar
I have a Smarty and its set on level 5 mild TM and my truck has a noticeable timing rattle now so I was wondering if anyone knows a way to get rid that. Would the aftermarket injector setting lessen the timing and relieve it a little bit? Anyone else with this same problem? It's not a big deal but I really don't like how it sounds to me.
Old Nov 21, 2007 | 11:36 PM
DaveB.inVa's Avatar
Definitely try the aftermarket injector program. I had a very very slight timing rattle at part throttle. I went to aftermarket injector stock torque management for smoke issues, however the timing rattle is completely gone. I'm also using SW 1 which, from what I understand, has slightly more timing for fuel economy.
Old Nov 22, 2007 | 06:56 PM
wow i'm overwhelmed with all the help haha
Old Nov 23, 2007 | 06:14 PM
LVTony's Avatar
Whatdya want? Dave gave you the right answer and only minutes after you asked. How many other people do you need to answer with the same info?
Old Nov 23, 2007 | 08:05 PM
BBarnett's Avatar
The after mkt injectors program reduced timing rattle in my truck and also reduced the power as well. I tried after mkt. inj. and turbo with the wild tq. mngmt. and it was a dog compared to the factory inj. and turbo with moderate tq. mngmt...
Old Nov 23, 2007 | 08:39 PM
DaveB.inVa's Avatar
I will agree that some of the fun was gone when I changed over. But the reduction in smoke, for me, more than made up for the power loss.
I was just tired of constantly watching the tailpipe and driving like there was an egg under the pedal.
Its not really that I minded the smoke, but I really didn't want to attract that much attention to my truck. From what I saw I would've been about the smokiest thing around here.
I can still lay a decent cloud out though which is great for tailgaters!
Old Nov 23, 2007 | 08:58 PM
toddschwantes's Avatar
Try the new Beta 4.x programming
You may want to give the new Beta 4.x programming a try. My truck had some rattle with an older version and this version has pretty much zero rattle, at least on my truck. This is the new version of the programming that is due to be released soon (an update of the 4.2, 4.3, 4.4 series that are discussed in so many threads). Todd Schwantes.
Old Nov 24, 2007 | 12:15 AM
jgiachino's Avatar
Originally Posted by toddschwantes
(an update of the 4.2, 4.3, 4.4 series that are discussed in so many threads)..
Agree, it'll help with the smoke / rattle....but it's much diff than 4.2-4.4...as there's no pressure and it's got a more mild power curve.
Old Nov 25, 2007 | 07:34 PM
I guess I meant to say the new Smarty Beta is based on the 4.2 4.3 4.4, with "normal" power levels at each setting. I think with the previous Betas all levels were like +170 hp.
Mopar72
Nov 23, 2007 07:43 AM
Honkylips
Oct 23, 2007 08:59 PM
N.Johnson
May 15, 2007 09:01 PM
timber
May 12, 2007 07:12 AM
Megaramasaur
May 12, 2007 01:06 AM
