Smarty SR Problem
Old Jun 6, 2009 | 12:10 AM
ltw's Avatar
ltw
Smarty SR Problem
Anyone have it where the truck was bucking and would barely make it up a hill. The pyro went from 600-1000 real quick. Check engine light came on and then retrieved the code 1203 and 2146. Unplugged Smarty and seems to be ok. Did the Smarty give up the ghost.
Old Jun 6, 2009 | 09:33 AM
MikeyB's Avatar
I don't recognize those codes as engine codes. How did you retrieve the codes? Key ON/OFF/ON three times or with the SMARTY?
MikeyB
Old Jun 6, 2009 | 11:33 PM
ltw's Avatar
ltw
I got it with the Smarty. All seems to be well today but have no programmer. Sucks at this point.
Old Jun 7, 2009 | 07:05 AM
MikeyB's Avatar
I say reload the SMARTY and see it the issue comes back.
And are you running an aftermarket lift pump? I don't see one in your sig.
MikeyB
Old Jun 7, 2009 | 07:32 AM
madhat's Avatar
Administrator/Jarhead
What program are you running with the smarty? I don't think that the TNT worked well with the 03 and early 04's.
Old Jun 7, 2009 | 11:40 AM
ltw's Avatar
ltw
I am running a stock pump. Truck is set at 60 hp as I have stock trans. Loved the mileage and extra power. I don't have the TNT as I have the revo. I will try and reload. The Smarty code showed injector circuit # 3 bank.
Old Jun 7, 2009 | 02:41 PM
madhat's Avatar
I don't see a fp gauge in your sig, or rail pressure... do you have either?
Old Jun 7, 2009 | 03:06 PM
ltw's Avatar
ltw
No, I can hear the lift pump running and it is now working good with no programmer. I just changed the fuel filter and have done every 6 months. I have new injectors as well as a new injection pump. I have about 8000 kms on those new from Chrylser. If I reload the program do I need to reload on the truck or reload the Smarty Software from the site.
Old Jun 7, 2009 | 05:32 PM
MikeyB's Avatar
Just reload the SMARTY program to the truck's ECM.
Possibility that the stock lift pump is getting weak. And with the extra demand for fuel from the SMARTY programming it's showing up.
MikeyB
stock03
34
Apr 21, 2011 07:40 AM
RyeThomas
40
Apr 20, 2007 10:12 PM
BigBlue
Nov 22, 2006 02:46 PM
bnold
39
Jun 4, 2006 08:21 AM
CTD_Neil
Feb 23, 2006 09:27 PM
