SMARTY Rocks!! (the sled...)
Old Aug 12, 2006 | 03:55 AM
PourinDiesel's Avatar
Well tonight I had a couple more tricks to throw at the sled out in Gaston, Indiana.
I was running behind all day as usual and got up to the pull and had not even so much as plugged the SMARTY in.
Well, I did, then I loaded in #9.
I noticed right away it had very aggressive low end fueling. I was just wondering what it would do up top.
I signed up for the ProStreet Diesel 8500lb class and then.....(I'll let you guys decided how it did) :-laf
Click here to see Video
Old Aug 12, 2006 | 04:08 AM
CSAGrey1's Avatar
SWEET__----Kudo's
Old Aug 12, 2006 | 04:31 AM
TexasCTD's Avatar
Very impressive Justin!!!
Hey, what are those sparks that i see in the video under your truck just a second or two after you launch?
Keep up the great work! I'll probably never hook up to a sled myself, but I enjoy watching you do it. You are one of my Cummins Diesel heros!
Old Aug 12, 2006 | 07:45 AM
lmills's Avatar
Very Shweet Justin. So, I take it you like the Smarty.
TexasCTD- the sparks are from the clutch
Old Aug 12, 2006 | 01:20 PM
Yeah SMARTY seems to be running well.
Glad I was able to drive home and have a successful pull last night.
Old Aug 12, 2006 | 03:11 PM
genros's Avatar
justin
did you stack the smarty or disconnect the other boxes
Old Aug 12, 2006 | 03:18 PM
Nah..I just programmed the smarty in on #9 with the other boxes connected.
I only ran the TS box on about 20% and turned the TST down to 0x0.
Old Aug 12, 2006 | 03:48 PM
texaspower19's Avatar
how many rpms are u lanching at and wat du run down the track, and wat gear, if u dont mind me asking.
Old Aug 12, 2006 | 03:51 PM
About 3600-3700rpm's @ launch. Down the track rpm's depends on sled weight, track conditions and what gear I am using. That run was about 3100-3200rpm down the track from what I can tell.
That run was in 2nd gear Hi range.
Old Aug 12, 2006 | 03:53 PM
ok ive been runing about the same R's but im going 4th 4low
Old Aug 12, 2006 | 11:51 PM
TexasCTD's Avatar
Ohhhh OK! Thanks. Duh.
I have an auto...so I didn't think about that.
Old Aug 13, 2006 | 12:33 AM
House's Avatar
It rocks Justin, plain and simple!!! your my hero!!!
coreydr2003
MODTR #30
27
Oct 1, 2009 04:56 PM
Pitz
42
Nov 1, 2008 10:23 AM
Seelow
Jul 26, 2008 03:21 PM
Don M
19
Oct 18, 2007 12:34 PM
schorb
17
Mar 2, 2007 04:23 PM
