Smarty Programs...
Old Jan 7, 2008 | 02:25 PM
cquestad's Avatar
Smarty Programs...
Beta 4.3 or 4.4 vs the new 4.10 or 4.12 software?
Can I go back to Beta 4.3 or Beta 4.4? I think I am still short on CP3 is my main problem...but which program is the dyno buster that still has linear throttle response and reasonable smoke/street manners.
Let the opinions fly...thanks!
Old Jan 7, 2008 | 02:33 PM
soulezoo's Avatar
DTR 1st Sergeant
I'd say definitely 4.4. And Marco did an "emergency" revise of that to work for the folks that had already used that "latest" DC flash that disallowed using the old programs. PM Mr. Wagner about it.
But honestly, I think that using 4.10 or 4.11 with the MP-8 just puts you at beta performance levels anyway or at least so close as to not worry about the difference.
Old Jan 7, 2008 | 04:15 PM
jlibert's Avatar
beta 4.4 is MUCH MUCH stronger than anything on the mads site.
Old Jan 7, 2008 | 04:17 PM
molalla1ton's Avatar
I thought 4.2 was???
Old Jan 7, 2008 | 04:26 PM
cquestad's Avatar
Can I go back...or should I just wait for the new race program?
I still think I am going to sit on this one for a while...and fix my cp3 fuel supply problem.
Old Jan 7, 2008 | 04:32 PM
tritont's Avatar
this is a quote from Bob in another thread..........
The 2006 and 2007 trucks are not affected by any chrysler updates so that is why the beta's work for you
Chrysler did updates for the 2003 2004 and 2005 truck which forced us to add their fixes to the smarty.
In other words.... if you have a 06 or 07, going back isn't a problem. If you don't... there's no going back.
Old Jan 7, 2008 | 04:43 PM
TORQUE BEAST's Avatar
The beta's are a lot stronger. 4.2 works on my truck the best. Smoother and lower egt's and less tq management than the 4.4
Old Jan 7, 2008 | 04:47 PM
Ghost Ram's Avatar
i just bought a new smarty from dtr last week, what program did it come with?
Old Jan 7, 2008 | 05:07 PM
rammv's Avatar
stock inj and turbo mild torque managment.
Old Jan 7, 2008 | 05:13 PM
Ghost Ram's Avatar
yeah, i just spoke w/ bob wagner and it came w/ the 4.11 170 hp. mild tq program. and he also said it boost fools, more boost the higher levels you go.
Old Jan 7, 2008 | 05:15 PM
BossHogg's Avatar
I have an 04 that had the Smarty beta 4.4 loaded and Im pretty sure in Oct. they reflashed my truck. Maybe not, but I now have some horn honking situation on my truck when its in reverse and the door is open.
....but I still seem to have my software loaded, ie. I didnt have to reprogram after leaving the dealership. Its still on there. Still seems strong, but I havent switched from lvl 3.
Do you guy's think its still on there? How can you tell if you had a 4.4 program on, then went to the dealer and there was still power added from the Smarty? It wouldnt have gone back to a stock smarty or messed it up could it?
Old Jan 7, 2008 | 06:03 PM
tritont's Avatar
If you had your truck flashed... the sw isn't on there. I'm really surprise they didn't see that it was on there if that's how you took it to them.
You just need to plug in the smarty to your truck and the first or second screen will tell you whether there's a program loaded or if it's the stock sw.
Old Jan 7, 2008 | 07:44 PM
GaveUpOnTV's Avatar
I heard your kinda 'up the creek' if they flash your truck while Smarty is on there. The Smarty will think that you're trying to load it on more than one truck and if the truck is flashed (while Smarty is installed) the Smarty hardware will be VIN locked.
I remember reading warnings about that I think in paperwork I recieved with the Smarty.
Old Jan 7, 2008 | 09:38 PM
jgiachino's Avatar
I've tried 4.2, 4.3, 4.4 and i prefer 4.4 as it makes all the power of the 4.2 and 4.3....it's just a touch smoother throttle sensitivity.....any of them are monsters compared to the standard smarty software.....i dont think you'd be disappointed with any of them vs the standards....if you're on an older version of the smarty software and havent yet tried 4.3 or 4.4....give it a try....if you dont like it, go to the current standard smarty softwares....but i'll bet the farm you like the betas.
Old Jan 8, 2008 | 06:44 AM
wap's Avatar
wap
I you can get it I would say go for the 4.4 also. I have tried the others and the 4.4 is much nicer to drive on my truck and from what I have read they all dyno within 5-10hp of each other and they are all pretty equal in the 1/4 too.
