Smarty mileage
Old Jun 19, 2007 | 10:47 PM
XLR8R's Avatar
Smarty mileage
What Smarty setting on which SW version is best for mileage gains?
... so many choices on Mad's website!
Old Jun 20, 2007 | 07:05 AM
MikeyB's Avatar
Mike, I don't know. I hear so many stories on which levels gives the best fuel economy but my guess it's really determined by your driving style (and truck). I haven't noticed a big gain, picked up maybe around 1mpg highway if I drive conservatively on level 5. No change for around town driving.
MikeyB
Old Jun 20, 2007 | 07:40 AM
KKB's Avatar
KKB
I have always gotten better mileage on 7 or 9 if you can still drive it normally. Wait for the beta versions to come out, I saw 20.2 on my first tank on #5, when normally it would have been around 18.
Old Jun 20, 2007 | 08:10 AM
tcr's Avatar
tcr
SAME HERE, level 7 gives me the best milage on the Mod TM software. The 4.3 beta gives even better milage, but I drive too much for the beta as a DD.
Old Jun 20, 2007 | 09:19 AM
soulezoo's Avatar
DTR 1st Sergeant
My last tank was 20.86 mpg on beta 4.4 sw3. You have to experiment a little to find what works for you. If there is a lot of in town driving stay on the lower sw's. If mostly highway you can get away with the higher ones. That has been my experience so far. beta 4.3 also is able to provide good mileage on the highway but is so sensitive and wanting to accelerate all the time it is hard to keep your foot out of it. (but it is fun! though)
Old Jun 20, 2007 | 09:24 AM
dodgezilla04's Avatar
smarty has lowered my mileage drastically. cause I cant keep my foot out of it
Old Jun 20, 2007 | 09:33 AM
10mm's Avatar
I am seeing the same as soulezoo. I get the best highway mileage on mild tq mgmt sw #9. For around town stop and go I get best mileage on sw #3. I pretty much keep it at sw #5 to control smoke when I am doing mixed city/highway driving and if I am going to be on the highway for a long trip I will load #9. Of course this is all contingent on being able to keep the right foot under control.
Old Jun 20, 2007 | 09:37 AM
XLR8R's Avatar
I have the stock injectors/turbo SW with moderate torque management - even #5 is kinda smoky, I've watched a few mpgs fog out an intersection when I forgot to feather the throttle.
Sounds like the beta 4.X version is best for reduced smoke with more power?
Old Jun 20, 2007 | 09:46 AM
4.4 is more controllable smoke mike, you can still turn day into night with it if you try.
there is more power, smoother throttle curve, and i did get better mileage with it towing that before, i had it on level 3.
hey btw, where's my boe?
Old Jun 20, 2007 | 09:48 AM
soulezoo's Avatar
DTR 1st Sergeant
Beta 4.4 will produce smoke as well. The higher the sw... the more smoke. Especially lower rpm before the turbo spools.
Remember: more power is from more fuel. More fuel with same air = smoke. Get more air= even more power, less smoke. Can't have everything!!
Old Jun 20, 2007 | 09:52 AM
XLR8R's Avatar
Hey Chris!
Do you have a standard Quad Race, or one of those modded units w/no timing for stacking? If it's a regular Race like mine, do you stick to SW#8 or have you tried #9 with the Quad turned up?
p.s. both our BOEs are sitting on a Velocity truck somewhere... darn parts vendors!
I have to stay in the office today just to make sure we get this shipment.
Old Jun 20, 2007 | 10:04 AM
i have a non modded race, i only run even with it(no studs). i did try the 4.3 on 8 and cranked up the quad. whooo hoooo really fast.
4.2 and race cranked up=blown freeze plug
cant wait for the boe(need the peace of mind) thanks
Old Jun 20, 2007 | 10:28 AM
rustyshakelford's Avatar
as much as i loved 4.4, im going back to the software i have from dec. 06. the beta was a bit to strong and my tranny developed a shudder on acceleration. i cant wait till the full version comes out. i will get the mild trq mang and i bet it will be almost perfect. the milage was looking very promising also
brett
Old Jun 20, 2007 | 10:32 AM
XLR8R's Avatar
I set the Quad on PL3 and loaded SW#9 ( )... I know it's not best for a stock HPCR, but hey - this is our shop truck for testing & demo(lition?)
Gauge-wise, the abuse appeared to be quite repeatable!
I think the excessive fueling helps to dampen the fire.
Good thing I had the sense to leave the H2O/CH3OH & NO2 master switch off - otherwise there might've been a Ram-sized mushroom cloud.
Old Jun 20, 2007 | 10:36 AM
XLR8R's Avatar
As soon as we loaded the Smarty, I knew something was different when I cranked up the Cummins. Puffs of smoke off idle in the bay, and a very sensitive accelerator; smoke-free operation requires no more than 10% movement on the skinny pedal.
