Smarty Jr. and towing
The second setting is called tow mode, so that's what I would use. If you have a manual you could probably tow in any of the three.
These are my opinions for towing.
level 1 = 40 Hp says economy mode = safe for auto or manual.
level 2 = 70 Hp says towing mode = safe but marginal for auto or manual.
level 3 = 100 Hp performance mode = unsafe for auto, marginal for manual.
Alot really depends on how you use the power. You could use every setting for towing if you use common sence and don't stab the throttle towing. Your towing not racing.
I am wondering how you determine that? I am saving up for the Jr and tow a horse trailer that is about 7k lbs loaded with a stock tranny. I assumed that towing on level 2 would be safe from what I have read from MADS here on this forum. The Quad XZT adds 65 hp and is supposedly safe for towing loads, why not the JR?
I guess my question is, what are the weight to +hp factors in determining what level to use when towing with a stock tranny? I have pulled around 19k lbs when hauling hay. Can I only run stock if I should do that again?
I've towing for two years now with the quad standard on the 60hp mode with a 11-12k 5th wheel. Not a problem. I'm gonna switch to the Smarty JR soon- Methinks...
stock03
34
04-21-2011 07:40 AM
D.Wiggs
31
08-30-2007 02:48 PM
RC51
02-17-2007 08:54 PM
