Smarty Help Please???
Old Mar 14, 2007 | 08:01 AM
04smoker's Avatar
Does anyone have any idea how to install the wild torque managment upgrades?
Old Mar 14, 2007 | 08:41 AM
MikeyB's Avatar
Here's a thread on downloading to the SMARTY.
Get the files from here...assuming you have the S04 version.
https://www.dieseltruckresource.com/...d.php?t=124407
MikeyB
Old Mar 14, 2007 | 06:40 PM
04smoker's Avatar
No, it's an s06. guess that wont work, huh??????????????
Old Mar 14, 2007 | 07:12 PM
Green04HO's Avatar
with the S-06 you need to download the 7 zip program at the bottom of the Smarty download page to unzip the download files.
Download Smarty USB downloader ver. 3.04A optimized for Windows XP,Smarty USB driver for Windows 2000 and Windows XP, and the program file that you want to run.
Create a folder in your documents and save all downloads there. Unzip using 7 zip for the Smarty program file (ie: wild progam) Plug Smarty into computer and it will open window, do not let windows select best driver instead browse for cdm2.00.00 wich is unzipped in your new folder select and install as your driver. Then select the smarty USB icon and open, next click on the file tab on upper left side of USB window, next click open and another window pops up search for the Smarty file in your newly created folder (ie: wild program) double click that progam and the Smarty USB window will pop up click send.
That should be all you need.
Old Mar 14, 2007 | 07:23 PM
MikeyB's Avatar
Here's the S06 files..
http://www.madselectronics.com/DownloadMODS06A.html
MikeyB
Old Mar 14, 2007 | 07:27 PM
04smoker's Avatar
Thanks a bunch! So how "wild" is this wild program anyways? And is it similar to the bully dog in thatthe torque management is good for all levels of power or is ti good for only the highest settings? Sorry for the ignorance but I am new to the smarty game.
Old Mar 14, 2007 | 07:29 PM
04smoker's Avatar
Still don't know how to post a sig. so maybe you guys could help with that as well. (Not to sharp on this computer device.)
Old Mar 14, 2007 | 07:30 PM
MikeyB's Avatar
I don't know but I hope you have a modified transmission! I assume with the wild the torque management will be very aggressive in all levels.
Go to User CP towards the top of the forum page and select Signatures.
MikeyB
Old Mar 14, 2007 | 07:31 PM
P.J's Avatar
P.J
Up on the left hand side there,....you see "user cp"? click that, most of your controls are in there.
Old Mar 14, 2007 | 07:34 PM
RamWheelsBy4's Avatar
Click on the "User CP" menu above. Click on the Edit Signature on the left. Type in your truck and mods and click on Save Signature.
If it does not show up in your posts the you go to User CP and click on Edit Options. At the bottom of the options is a box for Show Signature, click in the box to check it and then save changes.
That should do it.
Dam I'm slow today.
Old Mar 14, 2007 | 07:42 PM
04smoker's Avatar
Thanks again guys Not to good on this thing but I'm learning fast!!!!!
Old Mar 14, 2007 | 07:57 PM
04smoker's Avatar
So can anyone tell me what I stand to gain by doing this "wild " program?
Old Mar 14, 2007 | 08:00 PM
Green04HO's Avatar
The wild program will fuel hard down low. It removes alot of the torque management. How much it removes is proprietary info though.
Old Mar 14, 2007 | 08:10 PM
04smoker's Avatar
Curious? Does it fuel like my crazy larry did with the torque managment or harder? Just lookin for a little input. Or is the moderate torque managment good too??
Old Mar 14, 2007 | 08:52 PM
04smoker's Avatar
Any info would be greatly appreciated guys. As I am looking to do the upgrade now....
