Smarty Help Please???
Old Mar 14, 2007 | 08:54 PM
04smoker's Avatar
Please??????????????
Old Mar 14, 2007 | 09:03 PM
Green04HO's Avatar
I wish I could help you, but I have no experience with the crazy larry program. Maybe others will chime in.
Old Mar 14, 2007 | 09:31 PM
MikeyB's Avatar
Has your transmission been modified? Like the valve body and torque converter?
MikeyB
Old Mar 15, 2007 | 09:58 AM
JohnInNH's Avatar
If it's stock... I would not use the WILD... Moderate was fine on my pre SB clutch 6 speed. I bet a stock auto will HATE the WILD.
Wild is not recomended for a stock auto tranny anyway.
I run Wild at #9 and it's hard to manage 2nd gear LOL a little to easy to jerk the truck on bumps!. 3 rd is better and 4th is fine.
The throttle is real touchy on WILD
I can just imagine an auto dealing with that
Old Mar 15, 2007 | 11:34 AM
MikeyB's Avatar
Originally Posted by 04smoker
Any info would be greatly appreciated guys. As I am looking to do the upgrade now....
Seeing that you have your sig updated I say go for the wild.
MikeyB
Old Mar 15, 2007 | 05:42 PM
04smoker's Avatar
Sweet!!! Gonna try it tommorrow.
Old Mar 15, 2007 | 06:51 PM
jwb600's Avatar
I dont think the smarty fuels as hard down low on 9 as crazy larry but up & moving I think it is very comparable to crazy larry. I was wanting someone to explain more on how to download the better programs for the 06. it explains it on mads website but im not the best with computers. I was wanting to download the program for the built trans. I dont care for the timing it has. I put in 8 w/no timing and put it right back on 9.
Old Mar 16, 2007 | 02:02 AM
ramtd02's Avatar
smarty wild removes tourqe management, so your peddle will be touchy, you will have the responsiveness of a 450hp gasser, probably worse due too the torque. So simply said mine is awesome, the whole truck twists and goes!
Old Mar 18, 2007 | 12:33 AM
doznfire's Avatar
I just installed the smarty on my 06 6spd. On the 90 horse setting W/timing, rolling into it in 6th gear it acts weird when you let up and step on the clutch coming up to a stop sign. The clutch peddle gets hard and almost can't get it out of gear..... Any thoughts? No tire spinning or driving stupid, just rolling into the throttle.
Old Mar 18, 2007 | 05:27 AM
jwb600's Avatar
when I first downloaded mine it done alot of weird stuff. I have had thoughts of returning the smarty. I would not give it a second thought on keeping it if it were cheaper than 685, but thats alot of cash for a downloader compared to others at 400 or so. I do like if you want it to smoke it will. I can take of from a dead stop and roll it out if needed. my truck acted like at first it wanted to keep going when It was first downloaded at a stop sign. I dont care for all the timing, it rattles something horrible when its cold.
Old Mar 18, 2007 | 06:52 AM
MikeyB's Avatar
Classic symptom of a slipping clutch. I would back down to level 3.
MikeyB
Old Mar 18, 2007 | 06:54 AM
MikeyB's Avatar
Try the software version for aftermarket injectors. Reduces the timing compared to the stock version.
MikeyB
Old Mar 18, 2007 | 12:31 PM
doznfire's Avatar
MikeyB
I have slipped a few clutches with the old truck, I have never experienced the hard to push clutch before...Is this a characteristic of the 2 piece flywheel set up?
Old Mar 18, 2007 | 02:31 PM
Black04Ram's Avatar
Can you run the wild setting on a stock truck without aftermarket injectors or a turbo? Thanks.
Old Mar 19, 2007 | 07:14 AM
MikeyB's Avatar
The clutch plates gets hot and sticks to the flywheel which causes the hard pedal pressure.
Really should look into replacing the clutch. Like from South Bend.
MikeyB
