Smarty and edge juice with attitude??
I don't think I would try it. Sounds like you will probably start to run really hot really quick. If you give it a try let us know how it goes. What would you benefit from running that. The Juice does not do pressure at all. It is timing and duration. Keep us posted.
It will work to give you some instant adjustability, but it will not increase your overall power. In other words, loading smarty on 4 and running juice on 3 will not give you better performance that smarty on 9. No combo of the two gives as much power as TNT 9 by itself. What it allows you do do is drive around with smarty on a lower setting and then flip the juice up if wanted.
Fire Rescue124
Jul 9, 2008 08:48 AM
cbrahs
Aug 21, 2007 10:05 AM
CumminsDreamin
Feb 13, 2007 08:01 PM
hotrod929
18
Feb 13, 2007 05:51 AM
razor6
22
Jan 20, 2006 03:43 PM
