Smarty Differances
Old May 3, 2010 | 08:39 AM
dieseloutlaw1's Avatar
Smarty Differances
I am looking in at ordering a Smarty. Don't know what to get.. What is the differance in the Smarty POD and the Smarty S-06?? how does the 100 power levels work on the POD, are 1-9 the same on both and 10-99 adjust things from there?? Any help would be awesome!!
Old May 3, 2010 | 09:31 AM
nwflyoda's Avatar
i just got one a few weeks ago. as far as i can tell the only difference is that the POD version will let you adjust the power level UP TO the level you tuned it with. once you have a tune loaded, you can "detune" it per se (any number under 99) and then if you want that power back you can set it back to full power (back to 99) if that makes sense. this is how i understand the POD version, but i don't really use that feature to my smarty. i just keep it on the main sw settings. hopefully that helps some.
stock600
Feb 29, 2008 03:45 PM
imjustdave@hotm
Jan 22, 2007 07:27 PM
fishin fever
Jan 16, 2006 08:54 AM
99 cummins
31
Apr 29, 2005 08:13 AM
Sarge1124
Sep 3, 2003 07:49 PM
