Smarty ?
Old Sep 13, 2007 | 02:57 PM
molalla1ton's Avatar
Smarty ?
I have a SMARTY on a 06 3500 auto. I see a lot of talk about SMARTY beta 4.4. My question is what is it and do you download it from Mads electronics?
Thanks in advance.
Old Sep 13, 2007 | 03:57 PM
dodgezilla04's Avatar
the betas are not downloadable. they are sent to us from bob wagner, who is the us smarty rep and resident guru.
the betas4.1, 4.2, 4.3, and 4.4 are beta testing programs for some new changes. 4.4 was supposed to be a towing program, but it ended up making a ton of power. it is smoother on the accel, increases rail pressure slightly, and does lower egt when towing. but its pretty powerful.
Old Sep 13, 2007 | 03:58 PM
2003Ram's Avatar
The Beta version is not a "Production" version, it's software currently under test.
Old Sep 13, 2007 | 05:14 PM
emfc_22's Avatar
and its the coolest thing ever. i spools the big turbo i have real quick. and as long as you don't dtick it to the floor and just accelerate aggresivly the smoke down low isn't bad at all. unless you want to then wow!
eric
i hope they don't change much on production downloads, thanks bob
Old Sep 13, 2007 | 05:21 PM
Bob Wagner's Avatar
oh there will be changes......
no problem eric
Old Sep 13, 2007 | 05:51 PM
emfc_22's Avatar
is there a hp difference in this upgrade or are things just moved around in the rpm range. and is there too much pressure to use a pressure box with it? i have no pressure gauge
Old Sep 13, 2007 | 06:41 PM
trx's Avatar
trx
are we getting any closer to having a release date on the beta 4.4? Are the changes just a detuned version. Cant wait to try it out been waiting for it for a while!!
Old Sep 14, 2007 | 06:00 AM
darrenb's Avatar
no problem eric
HA! I knew it!!!!!
Old Sep 14, 2007 | 07:32 AM
MikeyB's Avatar
Gee, might have to reload 4.4 to put a fling on my craving! (Level 1 of course).
MikeyB
Old Sep 14, 2007 | 07:47 AM
jgiachino's Avatar
-- I'm hoping for...
- add diff tq mgmt levels
- modify so level x = level x....not level 1 = 170hp! ....
- remove speed limiter
- add a tad on the bottom...but keep the beautiful mid / upper end
- keep the boost foolng the same as 4.4....mine pretty much stops
at 35psi (or is easy not to go over)....works good for stock turbo
- Makes coffee before 6am
Old Sep 14, 2007 | 03:33 PM
LVTony's Avatar
MikeyB
Careful! Even on level 1 of Beta 4.4, I could get my [stock] TC to slip when rolling into WOT at 75 mph. Having a manual tranny will help you a little more, but it's still too much power for stock equipment. I like it.
Old Sep 14, 2007 | 05:17 PM
MikeyB's Avatar
I did run level 5 for two weeks before the dyno numbers came out for 4.4!!!
Wondered why I was leaving black marks with normal 2nd gear take offs....
MikeyB
stock03
34
Apr 21, 2011 07:40 AM
RyeThomas
40
Apr 20, 2007 10:12 PM
BigBlue
Nov 22, 2006 02:46 PM
bnold
39
Jun 4, 2006 08:21 AM
CTD_Neil
Feb 23, 2006 09:27 PM
