Shift left logical
Old Aug 17, 2004 | 08:00 PM
spinlocker's Avatar
Shift left logical
Have an 03 6spd with a BD short shifter. Have any of you jacked around with moving the shifter to the left, say, the width of a hand? Seems to me the **** is about 4" too far to the right in stock position. Not sure if the shaft is cast, hollow, peuter, or what. I do know that a heating torch would make short order ot that vulcanized rubber cushion on the bottom of the shifter shaft. Ideas? Besides buying a new one in case I mullow the original?
Old Aug 18, 2004 | 05:30 AM
mightynorseman's Avatar
spinlocker,
Could you replace with an after-market "off-set" shifter?? Saw this on hot-rod show after trucks show.
Old Aug 18, 2004 | 01:33 PM
Jonbr's Avatar
It's easy to lift the boot, a couple of screws in the cup holder, then undue the long shift lever shaft. It's connected to a short shaft coming out of the transmission. Now with the long shaft out, you can bend it anyway you want.
Good luck I installed the short shifter in mine, that's why I know this.
Torque master
Aug 21, 2007 08:50 AM
morkable
Feb 17, 2007 11:31 AM
CASMOKIN
Competition / Pulls / OffRoad
Dec 30, 2005 01:28 PM
hotdram
Mar 8, 2005 11:01 AM
Checkmate
Feb 14, 2005 11:35 AM
