Next Logical Modd 600 rwhp goal
Old Aug 21, 2007 | 04:32 AM
Torque master's Avatar
What would be the best next step in the persuit of 575 Daily driver, No- Tow- No- Pull For work and play. I am guessing A modded CP3 pump / dual stock cp3 /
If I only plan to persure the 575- Max power,
what would be the ideal cp3 set-up. I here of the dreaded pulsing effects from a modded pump not sure if this was a vendor specific issue or not. Or if the issue has been resolved. Anyhow I just want it to run smooth as my Stock set-up does and maintain reliability.
again current Truck Mods: 05 Dodge Full Billet Trans- GDP-Walbro full lift pump system- Hot Edge Juice Stacked with Edge-EZ-- Silver-62-14 Turbo , ATS Exhaust manifold-- AFE stage-2 -- 4" Turboback Silverline Exhaust-- BD Boots-- will 50-hp Sticks and the rest of my Sig get me to 600 ?
Trying to avoid extreme smoke from larger injectors, been there done that with my 2-nd gen and mach-4 150-hp injectors in the past. Will and aftermarket intercooler start to come into play at this HP Range as I have the wonderful Matel plastic edtion on my 05.
Old Aug 21, 2007 | 06:46 AM
omaharam's Avatar
With Hot Juice, mp-8, Aurora 3k turbo, GDP 392, stage 1 cp3, I made 502hp and 1170tq. So no, 50hp sticks aren't going to get you to 600hp. I added Flux 1.8s and should be hitting the dyno in the next couple weeks. However, you don't want smoke and the 1.8s are smokey. I plan on doing compound turbos next spring which should take care of the smoke and put me well over 600hp.
Old Aug 21, 2007 | 07:31 AM
trik396's Avatar
Your setup is similar to mine and we both have 05's. I'm over 600rwhp now. Get a Diablo. You probably will need the intercooler. I changed mine out because I'm sure 50+psi was going to pop the plastic one eventually.
I don't have injectors or modded cp3.
Old Aug 21, 2007 | 08:50 AM
ramtd02's Avatar
I have custom 90hp ddp's (actually a 110) and a stage 2 cp3, and i dont get anymore smoke than i did with the standard smarty and stock injectors and cp3. I am up in the 650hp range, and i only run the beta smarty right now for electronics.
Mopar_Man
19
Nov 23, 2008 05:28 PM
NewbieDavid
15
Jul 20, 2008 09:54 PM
ridofpwrstroke
21
Dec 19, 2007 12:53 PM
Missouri_Mule
Jun 9, 2003 01:02 AM
