Shift Enhancer, Do they help?
Old Sep 3, 2008 | 10:21 PM
cvcook's Avatar
I'm Tired of my truck doing the 1-3 shift (only under light throttle), so I finally called goerends and talked to dave,and he's sending me a shift enhancer to fix it. so how do you guys like yours?
Old Sep 4, 2008 | 07:43 AM
paroxysym's Avatar
it was kind of required with his tranny or he would void your warranty after awhile. it helps i think. on the daily setting of the enhancer it gets through the gears smooth and puts it in overdrive around 45-55 mph depending on how hard youre on the throttle. ive only used race and daily. race kinda draws your gear shift points out to get your rpms up- def helps in my opinion. as for the towing mode, i tried it once by accident and its like race- draws your rpms out and shifts alittle firmer. you will like it, i think it helps the tranny IMO
Old Sep 4, 2008 | 08:55 AM
BIGDAN65's Avatar
i just got mine in last weekend, i had the TSB done before for the gov sol and went ahead and done the sensor too and that helped alot. the Shift enh def makes a dif when on race. my tranny is stock for now
Old Sep 4, 2008 | 10:41 AM
XLR8R's Avatar
I've driven with one in a customer's truck and although it helped, the tranny still shuttle shifts at higher TPS settings... Tow & Race are progressively better than Daily.
Old Sep 4, 2008 | 10:45 AM
tcr's Avatar
tcr
That's weird, mine only shuttle shifts under light throttle, but there's apparently not as much help for the 03-04s with throttle cable, is that right? As I understand it, there are no shift enhancers for 03-04s.
Old Sep 4, 2008 | 10:47 AM
RyeThomas's Avatar
Winner winner chicken dinner!
I think its all in how its programmed from DTT. Mine came with some tweaks that worked well on Tim Barbers 06 with alot of the same mods I have, so mine is spot on. This may not work as well say if someone has an 04 and a diferent DL, but who knows.
Old Sep 4, 2008 | 11:29 AM
BIGDAN65's Avatar
they are programmed for what you have, i got mine used and had to send it in and have it reprogrammed for a stock trans
Old Sep 4, 2008 | 11:43 AM
XLR8R's Avatar
The Shift Enhansers are only for the '05+ trucks... guess you can't use them with the underhood APPS (newer trucks have TPS on accelerator pedal).
I don't know how they are "programmed", other than the line pressures are manipulated to align the shifting with the truck's engine tune.
I suspect the underfueled, overgated twins contributed to the shuttling!
Old Sep 4, 2008 | 12:01 PM
no_6_oh_no's Avatar
The SE doesn't have anything to with the APPS, they hook to the TV motor that controls the gov pressure. Gov pressure is advanced based on APPS position. The SE cuts into the control wire for the TV motor and provides more gov pressure at lower APPS signal. Pre 05 trucks have a TV cable thats why the SE is useless on them.
The SE does not control line pressure only gov pressure. Line pressure is preset with springs on the PR valve. All the SE does is ramp gov pressure faster so it takes more line pressure to overcome it and cause the shift to happen.
The problem is little or no gov pressure at low throttle opening. This causes the the shuttle because a slight movement of the throttle will cause the trans to think it needs to downshift and then upshift again immediately as the line pressure rises with rpm.
The SE is configurable by a delaer with their tools for it. Each truck reacts a little different so you may have to find a dealer or send it back to get it tailored to your setup. There are parameters that DTT won't exceed on the control so if it can't be addressed with the SE ther eis most likely a mechanical issue that is causing the shuttle.
itr.#1446
Nov 9, 2008 09:03 PM
MoparRiggan
29
Nov 9, 2008 12:02 AM
Torque master
15
May 5, 2008 08:58 PM
cincydiesel
Jan 23, 2008 08:19 AM
Sixpack73
Nov 10, 2007 09:11 AM
