Relentless Diesel Twins and Jake?
Hey all;
I am preparing to get a set of Arctic Air Towing Twins from Relentless Diesel. I intend to run a TST box, for the fuel, as well. I currently have a Jacobs exhaust brake installed, and since I tow my antique John Deere's I have no intention of letting this go. I need some advice with regards to keeping this unit in conjunction with the twins. Any and all help will be greatly appreciated.
R/
Eric
R/
Eric
you might want to get a low end box the TST is for mid to high on the top end look into the smarty or diablo programer or at least get a pressure box so you a have low end power
You will need a 4" or 5" remote mount brake to work with your twins, depending on your exhaust size. The remote brake gets mounted in the exhaust system downstream of the twins. You should only need the brake itself, as the rest of the kit should work with it.
mm73
08-09-2008 07:16 PM
jbjarko
06-20-2007 08:31 AM
PanteraGSTK
22
02-23-2006 09:19 AM
