Rail Pressure Problems
Old Mar 29, 2008 | 05:56 PM
omaharam's Avatar
Originally Posted by OldSmokey
I plugged the quad in first to see if we got the same readings with the x2 gauge. The quad read just the same as the diprocol when it was plugged in first.
My bad. I was thinking x2 as in a power adder and you had it plugged in before the DiPricol gauge.
Old Mar 29, 2008 | 06:00 PM
OldSmokey's Avatar
Well its both but I wasnt adding any power this time.
Old Mar 30, 2008 | 10:51 AM
Silver 002's Avatar
hey Joel i finally found your post. Any new news?
I agree i think we eliminated the RV. but we could cap it to make sure.
And for the injectors...they could be bad so maybe still two sets monday.
Here is a some more up to date info this morning cruising at 70 with beta 4.3 on 9 i see right at 20000 at the rail. fuel pressure(right before CP3) is 18-19 and boost at the same time is a steady 10-11 pounds( stock charger). isnt that rail to high is is that normal with 4.3? under any pull it will suck it down to 14000 ish and try to struggle back up but doesnt exceed 20000 until it spikes after you let out of it. the spike is right around 22000 23000
Old Feb 16, 2009 | 11:27 AM
modified03's Avatar
Im have the same issues with my truck and it's an 03 with 150xxx on it though.
Old Aug 28, 2009 | 09:38 AM
DF5152's Avatar
what was the fix????
slimpicken
Feb 13, 2011 10:25 AM
rollin-a-cloud
15
Apr 28, 2008 04:41 PM
5.9Excursion
Mar 13, 2008 10:56 AM
jlibert
Dec 22, 2007 03:02 PM
out4elk
20
Aug 26, 2007 12:53 PM
