rail pressure gauges?????
Anything to do with rail pressure isn't going to cause timing rattle.
If your truck is running and you just unplugged the r/p gauge, the truck starts running rough and sounds like terrible timing rattle. This is the same thing that happens to me with the Quad r/p plugged up. Phil (Mcmopar) on here was with me once when it started doing it. Probably just a bad connector or soulder connection, but this is the second gauge I have had trouble with. Just wish the quality was up a little.
The Quad display can be difficult to read if it's really bright outside, especially if the sun is shining onto it. Probably not a problem if it's mounted under the dash in a dark spot, but frustrating with an instrument cluster mount like this:
91oldranchtruck
Feb 22, 2011 11:57 PM
5.9Excursion
Mar 13, 2008 10:56 AM
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
