Rail Pressure Gauge
Ok, we are going to see how this works.
The gauge will look like the Recon XZT physically. We had to do a new overlay obviously to read different.
The gauge will be first and foremost a rail pressure gauge. It will have a recall for min/max and you can set a warning. The gauge will be accurate to 10psi as we only have 4 digits so you will take the number X 10. Or you can just add a zero!
There will be an optional lift pump pressure kit if you want it. The kit will be identical to the Recon fuel pressure kit now. It has a 0-40psi sensor and includes the stainless tapped banjo bolt and new washers. This kit will be the same price as the Recon fp kit.
The gauge itself is about 35% cheaper than the Recon XZT.
It will be about 2 weeks and I will do a few beta test units although I don't need to really. Just a way to make darn sure we have what we want.
So, for you guys that want to test (its not free but, cheap) I will have a couple, first come first serve. I have to get the overlays and wiring finished first though!
Quad
Quad
Quad,
You guys are awesome!!!!! Keeping up with the customer demand really shows what you guys have to offer to us.
BTW, I would love to beta test.............................................. ..for long term useage.
If I do this I would probably need to use the Recon platform. Any problems with that?
http://www.quadzillapower.com/products/recon.html
I wished I could but, the Recon has some pretty fancy stuff on it as is to keep it in such a small package. The problem is the smaller packages have some downsides like RAM and I/O pins!
Also, I sort of got flooded with PM's. Like I said it will be a first come first serve basis and I have more than enough first come guys!!!! I will only do a couple as this is not really something that we are worried about.
I will let you guys know what is up in the next few days as I get more stuff ironed out!
Quad
You need to know if I do this it will be a rail pressure gauge with the option of adding fuel pressure. The other things the Recon does will not be available!
Quad
Quad
Quad thanks for clearing that up.
ken
We are only waiting on new overlays so it says the right things on the front!
Other than that it works well. I am going to send out another beta unit or maybe two in the next day or so.
DON"T PM ME, I have tons of pms from earlier in this thread.
We have one at Industrial Injection for them to test right now. I figured if they like it then we should be pretty good to go.
