Rail pressure
Old Mar 21, 2008 | 02:28 PM
Striper's Avatar
Rail pressure
Does the rail pressure normally flucuate somewhat at idle? I did a search and some people state that they will hold a set amount while others state between 4800-5600psi. Is this normal for it to jump around? Should it be holding steady at a given psi?
Old Mar 21, 2008 | 02:56 PM
dodgezilla04's Avatar
it is perfectly normal to fluctuate several hundred psi. no worries.
Old Mar 21, 2008 | 03:06 PM
Striper's Avatar
Thank you.
Old Mar 21, 2008 | 04:25 PM
ohyeahfriday's Avatar
Yeah, I wondered the same thing when I put the RP gauge in, it jumps around like crazy. Caught me all kinds of off guard.
My question: Do you guys see like 6** psi when you turn the key on, before the engine is even running? I never bothered asking before, but it is kind of on topic here...
Old Mar 21, 2008 | 04:54 PM
i have a digital rail gauge. when the engine is not running and key on, i see 0. idle is roughly 6k, cruising varies 14-19k, and wot 25K+
Old Mar 21, 2008 | 05:58 PM
OT-OF-Here's Avatar
rail pressure
Mine varies NO more than 300. 800 sounds like a lot of variance for just idling.
Old Mar 21, 2008 | 09:00 PM
CG98x's Avatar
Mine says 67 with the key on and it not running. MIne jumps around 200-300 psi at idle.
5.9Excursion
Mar 13, 2008 10:56 AM
jgiachino
16
Jul 11, 2007 07:33 PM
subspd
Dec 24, 2006 02:01 PM
rjm022
Dec 14, 2006 05:20 AM
mtl0727
Nov 5, 2005 06:47 PM
