Quick fuel pump question?
Old Apr 7, 2008 | 11:49 PM
VaultRam's Avatar
Was going to get the Raptor-100 kit but, low funds say otherwise. Right now I have the fuel canister nounted pump and only getting 4psi. Can I just get an in-line pump(walbro392,holley blue etc...) and splice the stock fuel line and use the factory return and just use the pump adapter? Is there anything I need besides the correct fittings and pump harrness?
Old Apr 8, 2008 | 10:19 AM
staarma's Avatar
If you run a Walbro like that, which is what the kit installs like anyway, you will need a pressure regulator. A Holley or Carter won't really be the best bet but will waste your money in the mean time.
Old Apr 8, 2008 | 10:40 AM
VaultRam's Avatar
Would the Simflo Regulator from Vulcan work? Does that also connect to the return....I'm not sure how that installs?
Old Apr 8, 2008 | 12:16 PM
shortbed rv's Avatar
The cheapest is to splice a holley blue. I went with the DIY Walbro and spliced a swagelok bypass adjustable regulator into the return line but the simflo will work just fine and is preset at 20 psi. Use a strainer/screen type filter before the walbro. the Walbro will pull more than stock therefore pickup things the stock pump would not. If you use the Holley remove the screen in the buttom of the pump. The screen can cause the holley to run dry.
There is a great article in the tech section about the Walbro install.
Old Apr 8, 2008 | 02:37 PM
staarma's Avatar
You basically T the supply line coming out of the Walbro and then one goes to the back of the filter housing and the other runs back to the filler neck with the regulator in line acting as it's own return. You can buy loose parts from Glacier to make your own kit and save a little here and there. He has some install instructions on his web site as well. You can look at those to give you a better overall on what the fuel system should look like once you're done.
http://www.glacierdieselpower.com/de...dept_id=43-001
Old Apr 8, 2008 | 04:49 PM
VaultRam's Avatar
So what happens to the factory return line going up beside the fuel filter canister? Do I use the dorman fittings to connect the pump to the factory hard line? Sorry for all the questions.....I'm having a case of the Mondays even though its Tuesday!
Old Apr 8, 2008 | 07:55 PM
http://wiki.dieseltruckresource.com/...l_Filter_Setup
1992gen1_fan
Dec 26, 2011 10:36 AM
HorseHauler
13
Mar 12, 2006 11:48 AM
NoSparkplugs
Feb 7, 2006 08:25 PM
caleb c.
Jan 19, 2005 09:18 PM
muddin4fun
May 19, 2004 11:46 PM
