quick bully dog question
Old Mar 6, 2007 | 02:18 PM
JONNY06DIEZAL's Avatar
one of my friends is letting me try out this tripple dog. no crazy larry. i havent done any performance mods yet other than straight exhaust. have no gauges. i havent put it up past performance mode yet. what precautions do i need to take while trying this out to keep anything from getting too hot or messing anything up.
thanks alot
Old Mar 6, 2007 | 02:20 PM
InFeRnO's Avatar
Performance will not get real hot but be careful not hold you foot in it for a long time. In my 05 I can keep my foot in it without it ever hitting 1100.
Old Mar 6, 2007 | 03:09 PM
alright, so you mean as long as i dont hold it at top speed or at a real high rpm for a long amount of time should be good. what about the extreme setting? have you seen that new bully dog pmt? suppose to come out on the 15th, i believe that is the route i will take. thanks
Old Mar 6, 2007 | 03:11 PM
JD Dearden's Avatar
I don't even look at my gauges unless I am pullin and i run crazy lar all the time and have big stupid injectors.
Old May 4, 2007 | 09:55 AM
Megaramasaur's Avatar
If you like the BDTD, I'll sell you mine cheap. I'm trying the Smarty for a while. I have crazy larry, but I also still have the regular software.. before all the changes that people have been complaining about...
I ran one on my 6 spd, and didn't worry about anything until I started running CL. Then I started to slip.... like everyone said, unless your pulling or really putting your foot in it, your temps should be manageable.
Old May 4, 2007 | 07:47 PM
duddin10's Avatar
I run mine on performance all the time. I do not have gauges and am not gonna get gauges. There is no need for them if you are smart and don't do anything stupid.
Old May 4, 2007 | 08:28 PM
notstrokin's Avatar
The gauges are good to monitor now and then, but for what you are asking you can turn it up as long as you dont abuse it for long periods of time.
Old May 5, 2007 | 01:43 PM
Jfaulkner's Avatar
Muted User
Just put one on a friends stock '06 and there is no difference between performance/extreme or crazy larry. Without a bigger fuel supply pump he doesn't have enough fuel to use anything above performance.
Old May 5, 2007 | 02:29 PM
StrokeThisCTD's Avatar
There is a difference on mine on a mostly stock truck.
Old May 5, 2007 | 04:30 PM
Jfaulkner's Avatar
Muted User
His truck was stock also except for AFE intake and aftermarket exhaust.
jnovotny27
Sep 23, 2010 07:55 PM
CLeger67
Apr 7, 2008 08:17 AM
Common
Aug 18, 2007 06:27 PM
Push Rod
Feb 8, 2003 07:51 PM
