Questions about boost gauges
Old Dec 26, 2010 | 10:12 PM
crodon963's Avatar
Can boost gauges be repaired? Got my truck at the end of June 2010 and it has Autometer pyrometer and vac/boost,the pyro works but the vac/boost does not. The needle is buried underneath the stop pin. If it can be fixed is it worth it or should I just buy another one? Is the vac/boost needed on a diesel engine or will just a boost gauge be enough? Thanks.
Old Dec 27, 2010 | 02:32 AM
brassnadz's Avatar
Just get a new gauge. Vac? Whats that? JK, you dont need a vacuum gauge. Turbos dont produce much vacuum.
Old Dec 27, 2010 | 10:24 AM
.boB's Avatar
Gauges can usually be repaired if sent back to the manufacturer. Autometer has a pretty good repair program.
Turbo engines often produce vacuum. Usually during closed throttle. My gauge runs off the OBDII port, and doesn't register vacuum. But I often see it at 0 boost.
Kman9090
29
Dec 6, 2007 06:43 PM
tex23455
Sep 15, 2007 10:50 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
AggiePhil
Jan 30, 2005 01:15 PM
