Question about exhaust
I just bought a 2006 Ram 2500 SLT Quad Cab truck. Can everyone give me their opinion on which aftermarket exhaust I should go with. My dad has a powerstroke with 4 inch exhaust on it and it sounds really good. Also can I add just a muffler and exhaust tip or do I need to add stainless pipes as well.
Your truck already HAS 4". I would recommend (although I have yet to do myself) straight piping (muffler delete) it and adding a 5" or bigger tip.
No need to go out and drop dough replacing a perfectly good exhaust.
If you had a 2nd gen I would say go for it (which I did), but not with a 2006.
dont forget guys,, that the stock exhaust system is only 3.5" for the turbo downpipe,, then goes to 4" also a aftermarket system tends to smooth out the flow of exhaust,, but that being said,, only if you are looking for lower EGT's will the downpipe be an issue,, in my personal situation I dropped allmost 200 degrees after the mbrp was put on.
Kevin
Kevin
Hoss
Nov 10, 2012 04:45 PM
greyrig05
Mar 31, 2005 02:54 PM
Hoss
Dec 20, 2004 11:13 AM
DPG
Aug 26, 2004 10:49 AM
