Question about edje juice and Valve body...
Old Sep 23, 2007 | 09:13 PM
Lrdchaos's Avatar
I recently purchased a juice with the A2 monitior. I mainly purchased it for the gps and the gauges in one package. My plans are to run it on a day to day basis on levels 1-2 and turning it off when I pull my 4500lb boat, I don't wanna strain the trans too much. Would you recommend just a vb, or just wait until I need the trans rebuilt and do it right then. Not gonna do anything else right now, other than a vb if that. I will wait for the tc until rebuild time comes along, then I will build it right. Thanks in advance.
Old Sep 23, 2007 | 09:28 PM
White97GTVert's Avatar
You will be able to tow on level 1 or 2 without worries.. At the least tow on 1 so you get a little benefit EGT wise from the timing, and maybe a tad better fuel mileage as well.
Old Sep 23, 2007 | 09:38 PM
inarush76's Avatar
Adding a valvebody will have several benefits. Better lube, better lockup pressure along with increased line pressure. Will help trans hold on till you are ready to do more.
James
Old Sep 23, 2007 | 09:47 PM
skynyrd's Avatar
a triple disc tc, first gear band set up, and turning up the stock valve body pressure should be good for pulling your boat with out a problem you really don't need a new vb. talk to dusty at HTS and let him know what your plans are for the truck and he will guide you in the right direction.
Old Sep 24, 2007 | 06:20 AM
Lrdchaos's Avatar
bump...........
Old Sep 24, 2007 | 11:28 AM
rufushusky's Avatar
Originally Posted by Lrdchaos
bump...........
Yeah right now I am shopping around for a TC and VB combo...I am torn over an input shaft as well....
Old Sep 24, 2007 | 11:56 AM
Dan Marino's Avatar
Just go ahead and upgrade to a valve body...its the "best" of your options
Old Sep 24, 2007 | 12:33 PM
GEN3TRQMONSTER's Avatar
Whats the best place to buy a vb if I have a freind that can install it?
Old Sep 24, 2007 | 02:33 PM
rufushusky's Avatar
Goerend, DTT, HTS and suncoast all make good valve bodies. I think I am going to go with HTS, but I am not married to it.
Old Sep 24, 2007 | 02:46 PM
omaharam's Avatar
Goerend. At least that's my opinion.
Old Sep 24, 2007 | 04:19 PM
bluebull's Avatar
click on this link www.goerend.com
Old Sep 24, 2007 | 05:41 PM
Justice4all's Avatar
I would steer clear of the Suncoast VB as it only a glorified Transgo kit. The HTS, Goerend, DTT are built with performance in mind by the best in the Mopar transmission industry. IMO the VB is probably the single best upgrade for your tranny aside from upgrading the whole thing. I went with HTS, and I'm sure the Goerend and DTT are also good units.
12ValverDave
Nov 15, 2008 03:50 PM
white250005
Oct 25, 2007 10:19 PM
kevellis32
Mar 25, 2007 08:54 PM
Igor
May 10, 2006 09:19 AM
razor6
22
Jan 20, 2006 03:43 PM
