Quadzilla Defuel and Warning Settings
Old Jun 20, 2007 | 08:22 PM
HarleyHauler's Avatar
I just installed my Quadzilla XZT and Commander and was wondering if anyone can give suggestions on levels that I should use for both defueling and warnings. I am not going crazy with my driving (most of the time) but I would like to make sure I don't overdo anything.
Any suggestions?
Old Jun 20, 2007 | 08:30 PM
vzdude's Avatar
DTR's 'Go to Guy'
I'm pretty sure mine are conservative with the following
EGT warn at 1300 defuel at 1350
Boost warn at 38 defuel at 39
Trans warn at 205 and defuel at 210
coolant warn at 210 and defuel at 215
fuel warns at 2 -
rail warns at 26000 and defuel at 27000
but I would like to know if I should set them lower! Just from what i read on here these should be close. My boost seems high probably, but its due to the smoke switch. It maxes the boost ( fools the module to full fuel ) . Actual boost hasn't been over 33.
Old Jun 20, 2007 | 08:34 PM
Thanks vzdude. I installed the Commander this weekend and have not had a chance to run it around too much since then (no towing, extended drives, etc.).
My max boost was 36 when punching it onto the hwy. Sounds like your numbers are good enough to start with. I will give them a shot and see how I do. I have to do some towing in the next two weeks so I will get a perspective then.
Old Jun 20, 2007 | 08:45 PM
vzdude's Avatar
DTR's 'Go to Guy'
I searched some of qzilla's post for my info, and lowered it a bit it to my liking. I sure hope if I gave out bad info he'll chime in!
Old Jun 20, 2007 | 09:13 PM
trik396's Avatar
Your info sounds good to me... very safe.
Old Jun 20, 2007 | 09:37 PM
shortbed rv's Avatar
My numbers are very close to Vzdude. For mods with just an XZT and air box mod I can hit 39 boost warning about the time fuel drops to 0 and I back off. Guessing, I would say about an 8th of a mile. Need more fuel!
Old Jun 20, 2007 | 09:52 PM
vzdude's Avatar
DTR's 'Go to Guy'
Sounds familiar! My boost doesn't get quite as high, but fuel goes to 0 fairly easy! Saving for the GDP kit!
Old Jun 20, 2007 | 10:01 PM
06CTDforAU's Avatar
That's about the same settings I plan to use in the Commander when I get it. How are yall liking the Commander so far?
Not trying to hijack this thread; sorry.......
Old Jun 20, 2007 | 10:45 PM
Luvnacumns's Avatar
Best Digital guages IMO out there!!!!
Old Jun 20, 2007 | 10:51 PM
Big T's Avatar
Will the commander defuel if you just have a smarty on and nothing else?
Old Jun 20, 2007 | 10:56 PM
So far I love it. I had some issues getting the gauges set the way I wanted them (the set-up directions weren't very clear and I kept getting multiples of some readouts) but otherwise I am pleased.
Performance is way better than I expected and MPG's are getting better than ever before (mild setting with the Smarty #3). Now it's time to save up for more modifications (CP3, trans, etc.).
Old Jun 20, 2007 | 11:01 PM
Luvnacumns's Avatar
The commander is set up to de-fuel on which ever paramaters you set it on say you set it to de-fuel on 1400 degrees pyro then no matter what setting the smarty is on once you hit 1400 degrees it defuels.. Atleast it does with mine and the mp-8
Old Jun 21, 2007 | 05:48 AM
vzdude's Avatar
DTR's 'Go to Guy'
I could be wrong, but I don't think so. The Commander can only defuel by turning down/off a box that it can control. It can't change a downloader.
shlen
Dec 21, 2014 12:22 AM
x1phats10x
Oct 27, 2009 09:07 PM
danalex
Mar 24, 2008 07:48 PM
Checkmate
Mar 23, 2008 09:10 PM
masonic-dodge
Feb 8, 2006 05:58 AM
