Quadzilla Commander (2001) Settings
Old Mar 23, 2008 | 11:33 AM
danalex's Avatar
Hi,
I just purchased a quad/cmdr; its in the mail. While I'm waiting, I'd like to gather some info as to what readings (numbers) I should anticipate for the various systems monitored. For example, EGT should be around xxxx; PSI should be between xx - xx; etc. Or if there is a link/post you know of that lists the various parameters/tolerances, then that'll be good too. Also, I'm supposing that each of the readings have a somewhat +/- range; please let me know that as well. Thanks yall!!
P.S. I'm sure some might have recommended a different mechanism rather than the quad/commander..too late, its paid for and in the mail, so I'm gonna give it a try. Thanks again!
Old Mar 23, 2008 | 04:17 PM
nike's Avatar
Just took my Commander off to replace with the Pulse....
With a stock truck my egt's were around 500-550 at 70mph.
Fuel PSI will differ with depending on your lift pump set-up, your're in danger if your reading is <5 PSI.
Boost depends on your foot input.
There are also +/- tolerances for each setting.
Any other questions feel free to ask....
Old Mar 24, 2008 | 05:42 PM
smokinram99's Avatar
where the Commander can be mount insted of Pillar??
What about the PULSE nike??
Old Mar 24, 2008 | 07:48 PM
nike's Avatar
Won't know about the pulse until it hits production.
Some are mounting in in replacement of an air conditioning vent...
x1phats10x
Oct 27, 2009 09:07 PM
norcaljr
13
Aug 5, 2008 10:13 AM
HarleyHauler
Jun 21, 2007 05:48 AM
stock03
Nov 9, 2006 11:27 PM
onesourceoil
Apr 12, 2006 01:17 PM
