Quad XZT - Is it a pressure box
The pressure increases that I have seen are minimal I mean around 10-15%. No shortened life of the CP3 should be expected at all because the pressures are still below the tolerances of the blow off valve which is what the system can safely run at. Basically the system has it's own failsafe for excessively high pressures, which, you won't get near with the XZT, Standard or Race. Trust me......go ahead and get the race! Once you feel the XZT you'll wanna feel the race!
Lot's of guys have cracked injectors with pressure above 26k. Also, without a lift pump, the cp3 is probably sending all the fuel to the rail to keep pressure up and if that's the case, it isn't using any fuel to cool it.
From everything I've read and the people I've talked to, you'd want a lift pump and injectors to run over 26k.
OX1
Jul 20, 2007 02:31 PM
Mopar72
21
Jun 29, 2007 01:07 PM
BigDodge1
Dec 5, 2006 04:46 PM
bama
Feb 12, 2006 06:58 AM
rammv
Jan 27, 2006 02:56 PM
