Quad Race Smoke Question
Old Nov 17, 2007 | 09:50 PM
Dynocon's Avatar
I have a Quad race Box and normally run on the 140 setting. It was installed 20K-30K ago. I seems that it has been smoking a little more lately. Is this normal? Does it have anything to do with the lower temps or do I need to run an injector cleaner thru it?
Old Nov 17, 2007 | 10:56 PM
CReed's Avatar
I run a fuel additive/ injector cleaner thru mine every other fuel fill up. The amount of carbon buildup we have been seeing from this cheap fuel is unreal. Injectors can use all the help they can get.
As for the smoke any recent changes in the air filter area you may check that out could be a little dirty etc. Lack of air will cause more smoke.
Old Nov 18, 2007 | 12:03 AM
spooling's Avatar
from my experience with my truck, there are many factors that affect amount of smoke. Air temperatures, humidity and elevation I think affect the different amounts of smoke I see
Old Nov 18, 2007 | 07:23 AM
Dynocon's Avatar
I changed the air filter a week ago so it is clean. I have never put any injector cleaner in so I will try some.
Thank
Old Nov 18, 2007 | 07:26 AM
mikmaze's Avatar
do you have an egt gauge in that truck and if so pre or post turbo, and what temps are you seeing?
QWKSLVRZ06
Nov 26, 2011 02:59 AM
BigBully
Mar 18, 2009 10:01 PM
BigJohnston
Feb 7, 2008 06:14 AM
jaredb900rr
Sep 7, 2006 10:13 AM
LinearX
14
Jun 14, 2005 04:48 PM
