Quad Boost Fooler = too much boost?
Old Jan 11, 2007 | 03:08 PM
ptgarcia's Avatar
Does the Triple Dog really benefit from a boost fooler? Does it not build enough (40 p.s.i. or so) boost on it's own? I just put one on my truck and haven't noticed what kind of boost my truck is making.
Old Jan 11, 2007 | 07:35 PM
973604x4's Avatar
Originally Posted by boostin
05 6speed with ez + hot juice stack, i thought that boost foolin was built into one of these,but sometimes it cuts out under high boost conditions like someone mentioned earlier and got me to wandering if maybe i need a boost fooler?
Juice boost fools. Your defuel limits are probably set too low on the Attitude. What is the defuel setting for the boost? i had to put mine at 40 to get it to work right.
Yes it benefits....No it doesn't make enough boost on its own.
It will hit 32psi in a hurry and thats no fun. Slap on a boost fooler and you pull harder all the way throughout the powerband and you won't get cut off at 32 anymore! definitely worth the price Quadzilla sells it for.
Old Jan 11, 2007 | 09:30 PM
texaspower19's Avatar
my tuck runs over 45psi daily since i got the triple dog back in feb, ive hit 48-50 wen i had stock intake manifold, 47 is all i can get out of it. i need a bigger turbo also, hit 1786 egts and kept it there for about 2 miles with tst, and crazy larry
Old Jan 11, 2007 | 10:18 PM
qzilla's Avatar
Just put your module on it and turn it to the OFF level. Then you have an expensive boost fooler and you can see for yourself!
Old Jan 11, 2007 | 10:59 PM
ptgarcia's Avatar
Good idea!
I spoke with Jeremy last week because I was having problems. I thought it was with the module but it turns out I have a broken connector on the harness. So, until I get that fixed I installed the Bully Dog (I really bought it just for the high idle and other features it could enable), but I can say I prefer the way the power comes on with the Xzillaraider. Also, my truck really likes the 60 h.p. setting on the Std. module. On that setting it purrs like a kitten until you romp on it, then it roars like a lion!.....Was that over the top? In all seriousness, my truck runs best on the 60 h.p. setting of the Quad Std. mudule.
jmccart
Apr 5, 2011 06:13 PM
Killdmycobra
Nov 12, 2010 05:15 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
Cumminsdieselboy
Oct 27, 2003 07:36 AM
Wes C
Dec 24, 2002 12:28 AM
