Pyrometer problem
Old Mar 22, 2010 | 04:13 PM
dodgedude361's Avatar
Pyrometer problem
hey folks. i am having a problem with my Autometer EGT. When I start the truck from cold all is well, within about ten minutes the gage stops working. It changes from reading zero, to about half it should.
Is this the thermocouple going? How hard is it gonna be to unscrew it from the manifold. I DID use anti seize.
TIA
Old Mar 22, 2010 | 04:19 PM
klx650a2's Avatar
Thats what happened with mine. Replacing mine was VERY easy as I used anti-seize as well. Screwed out very nicely.
You could try slapping the gauge also to see if it comes back.
Old Mar 22, 2010 | 04:34 PM
spoolinup's Avatar
X2
Also check your ground I found it was best to ground to the engine.
leonesm
Jul 20, 2009 11:39 AM
eric13
Apr 10, 2008 07:48 PM
biglar
Jul 15, 2007 06:13 PM
adgr71
Jan 14, 2003 01:07 PM
Push Rod
Oct 22, 2002 10:04 PM
