Isspro pyrometer problem
Old Apr 10, 2008 | 05:43 PM
eric13's Avatar
I recently sold an Isspro pyrometer to a member here and after he installed it he says it only reaches 400 degrees and moves real slow. I did a search but never found a real definitive answer. It worked perfect when I took it out of my truck and I would like to help him out. Any ideas will be appreciated.
Old Apr 10, 2008 | 06:02 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Bad ground hooking up the control box? Probe installed in-correctly? Loose wire connection at the probe lead wires? Or those connections could be shorting out a little?
Old Apr 10, 2008 | 06:16 PM
erics76's Avatar
Mine did the exact same thing. It did it for about half a day, about 3 or four times of turning the truck off and starting it, then started working again. No real help here, but at least it's not totally uncommon. I'd check the connections again.
Old Apr 10, 2008 | 07:48 PM
Fishin2Deep4U's Avatar
I had one Isspro thermocouple go bad. But as others have stated, check the connection and the box.
Dave
rip 112
20
Nov 1, 2008 06:30 PM
goronimal
Jul 1, 2007 04:50 PM
Shootist
Mar 4, 2005 10:26 PM
kelley15
Oct 9, 2004 04:46 PM
bigredbrick
Nov 7, 2003 11:47 PM
