pyrometer issue
Old Mar 12, 2014 | 08:49 PM
matt69olds's Avatar
pyrometer issue
My pyrometer reads correctly, until I turn the headlights on. Then the needle slowly drop, finally coming to a rest on the stop well below the lowest number on the scale. Turn the lights off, needle jump back up to normal. The gauge has been in the truck for years, it just started doing this within the last couple weeks. Its a Autometer Ultra-lite gauge if that matters. Suggestions?
Old Mar 13, 2014 | 07:47 AM
railroaderone's Avatar
Try unhooking the power for the gauge light and see what happens
Old Mar 13, 2014 | 07:20 PM
john40's Avatar
I had a similar problem a few years back and I called Autometer's tech. line. The tech. recommended a direct battery ground. I previously had an under dash chassis ground. This solved my problem, I hope it solves yours.
John
Old Mar 14, 2014 | 05:54 AM
comotionman's Avatar
Real pyros don't need any power to work.
Old Mar 14, 2014 | 11:10 AM
john40's Avatar
Well, I guess Autometer does not make a real pyro.
John
dan123dbl
Feb 13, 2015 05:47 PM
DDysput
May 5, 2004 07:44 AM
adgr71
Jan 14, 2003 01:07 PM
Push Rod
Oct 22, 2002 10:04 PM
