Pyro mounting
Old Aug 7, 2007 | 09:24 AM
Pav1973's Avatar
Pyro mounting
I got a ERG/Pyro guage from Dakota Digital and was trying to figure out were to place the probe,before or after the turbo?
A pict would be nice as well pls.
Pav
Old Aug 7, 2007 | 09:51 AM
TonyB's Avatar
MANY opinions....I suggest you search for 'pyro mount'....https://www.dieseltruckresource.com/...archid=1364179
More than enough reading and many pics!
HTH
Tony
Old Aug 7, 2007 | 09:57 AM
CTDinMT's Avatar
Pre. Only way to accurately know what is going on in your engine.
Old Aug 7, 2007 | 10:18 AM
Pav1973's Avatar
THx.
I did a search and there are sooo many post on it,it can make your head spin.
Pav
Old Aug 7, 2007 | 04:11 PM
Pav1973's Avatar
A little more help is needed here,i did a search and found no picts on were to place the probe pre turbo,anyone got any or a link?
Pav
Old Aug 7, 2007 | 04:25 PM
ripping r's Avatar
this should help.
http://www.dieselmanor.com/diy/CMS3-...ugeinstall.htm
Old Aug 7, 2007 | 07:08 PM
Mark03Ram's Avatar
Doesnt the number 1 cylinder run hottest?? If so I would think you would want the prob mounted on top towards the 1-3 side of the manifold. I would think it would give you a better average then right above the turbo. I would want to see the hottest exhaust temp the engine has.
Old Aug 7, 2007 | 07:23 PM
vzdude's Avatar
DTR's 'Go to Guy'
Actually #6 runs hottest. Furthest away from the water pump.
Old Aug 7, 2007 | 08:14 PM
Mark03Ram's Avatar
Cool good to know, that is the side of the manifold I will lean towards when I install mine.
Old Aug 7, 2007 | 09:09 PM
TonyB's Avatar
This is where mine is mounted....I 'creatively' borrowed the pic from this thread...https://www.dieseltruckresource.com/...gt+probe+mount
This is where mos have their probes placed.
HTH
Tony
Old Aug 7, 2007 | 10:17 PM
Pav1973's Avatar
THx guys,my search button is not working to good.
Pav
Old Aug 7, 2007 | 10:35 PM
THURENfab.'s Avatar
I mounted mine of the top of the manifold, just rear of the stock heat shield.
A few months back someone posted a vid of a turbo powerplant on a dyno, and you could see the manifold/header turn red. The manifold turned the brightest red, and changed colors the quickest, right before the turbo where the cylinders all join.
If I had to do it over again I think I would drill it in right before the manifold dumps into the turbo..
Old Aug 8, 2007 | 09:11 AM
TonyB's Avatar
I saw that video too! Wasn't that a gas motor? Same concept though!
Tony
Old Aug 8, 2007 | 09:32 AM
OR Mega Cab's Avatar
Could that also be caused by the manifold being slightly thinner right there? I am not saying it is, because I don't know, but if it were thinner, it would show heat on the exterior side the fastest in that area.
Old Aug 8, 2007 | 11:20 AM
TX_Diesel's Avatar
I had to put mine in the same place thuren put his, only because I couldnt' get my drill inbetween the mainfold and the body of the truck to mount it between cylinders 2 & 3. Where they all converge and dump into the turbo.
It's the same place that the Commander directions shows in the picture.
b.white
Mar 25, 2007 12:31 PM
NoSparkplugs
Aug 29, 2005 10:31 PM
engcogod
Nov 29, 2003 09:39 AM
atc250r
Mar 22, 2003 12:27 PM
