a problem with fuel pump....maybe
Old Apr 4, 2010 | 06:53 PM
mayhemryder's Avatar
i have a 2006 dodge ram 2500. my mods are a smarty with the revo tune set on 7 right now. a 5 inche exhuast from the turbo back a afe intake tube and a sb cold air intake. and a airdog 150 pump.
yesterday while goin down the highway my truck had a hiccup. and lost power and my check engine light came on so i pulled off the interstate and check the code and it was a po148 code. cleared it and drove alittle long. on my way back home the truck startdoin it again. it only does it when the truck goes into a load like goin up hill or pulln a trailer or puttin my foot into the peddle. i noticed that my fuel pump is shuttin off also. the pump has only been on my truck maybe 3 months. it was brand new when installed. ive checked wires and dont have anything loose.
ive thought maybe i didnt route the feed linefrom the tank to the pump the right way. ive thought bc its been warmer out that the pump is sucking the hose shut when the truck needs more fuel.
please if anyone can help im up for any ideas i can try before i call pure flow
Old Apr 4, 2010 | 06:58 PM
1985cucv's Avatar
the 150 should give you plenty of fuel for level 7 i would check your fuel filters to make sure they are ok. also i know on the fass systems the fuel pump relays can go bad so if the air dog is the same it might be an issue. it might be electrical related check out your connections.
Old Apr 4, 2010 | 07:06 PM
thanks ill go back over the connections.i checked my water seperator and no water. is that relay something i could find at autozone or o reilys. or is it something i have to order from pure flow
Old Apr 5, 2010 | 09:01 PM
1985cucv's Avatar
i would prolly get the ones for the airdog i dont know you might be able to get some cat filters or somthing they are the best!
Old Apr 6, 2010 | 12:56 PM
TOMCREEK's Avatar
tom creek
did you 45 the end of the draw tube, and held it off the bottom of the tank a quarter inch.if not, it may not draw enough fuel under hard excelleration.if it is to close to the bottom.Im sure you did, but if not run fuel line straight to cp3
joshuaray
Feb 12, 2008 09:44 PM
Tim9712v
Feb 23, 2007 07:51 AM
jiMMyCTD
Aug 31, 2004 09:47 PM
cummer01
May 27, 2004 04:07 AM
Cumminsdude
Apr 12, 2004 06:10 PM
