Problem...
Old Mar 6, 2011 | 03:17 PM
southpawslingr1's Avatar
Pulled all boost hoses do not see any cracks or sources if a leak
Old Mar 6, 2011 | 03:18 PM
AH64ID's Avatar
Did all the clamps look good?
The next step will be to pressurise the whole system from the turbo inlet. You may have to make a adapter with PVC and a tire fitting.
Old Mar 6, 2011 | 03:22 PM
Clamps look good everything was very hard to get off. Should there be oil in the tubes everything is bone dry
Old Mar 6, 2011 | 03:25 PM
AH64ID's Avatar
Should be no oil, that's an idication of a bad turbo seal..
One other thought is the WG actuator has failer internally, and even thou you plugged the boost reference line, the drive pressure may blow it open?
Going to be a hard one to test thou.
Old Mar 6, 2011 | 03:28 PM
no_6_oh_no's Avatar
How are you reading boost? Analog gauge or thru the data port?
Old Mar 6, 2011 | 03:32 PM
Analog gauge
Old Mar 8, 2011 | 01:16 AM
Ok im really confused now today driving the truck home just for the heck of it I got on the throttle and low and behold the truck acted like it had no problems. No loss of boost right up to forty lbs no problem. So now at this time its intermittent.
Old Mar 8, 2011 | 07:07 AM
AH64ID's Avatar
Maybe it was a boot slipping and in your moving them around it fixed it?
Old Mar 8, 2011 | 03:17 PM
I sure hope so! It still did it right after we got everything put back together but has not since.
CTD23
Jun 9, 2006 09:32 PM
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
