Porting The Turbine Inlet?
Old Jul 25, 2010 | 06:03 PM
EdmontonCanada's Avatar
Is there any value in porting the turbine inlet of a turbo for increased spool? I just received my Garrett dual ballbearing stage III...
Old Jul 25, 2010 | 07:17 PM
Blueboy's Avatar
I would match port to gasket.
Old Jul 25, 2010 | 08:01 PM
That's what you do for sure. But I'm wondering if the ATS manifold I have and the turbine ports are both the same size...because that's what you'd want to do...
Old Jul 25, 2010 | 08:28 PM
Blueboy's Avatar
Take your gasket put on manifold, use a black
marker to mark. Do the same with turbo.
Remove the black with grinder. You
just want to blend in, you don't need to
grind a lot out. You don't want to grind
the divider out.
DLittle
Nov 29, 2007 09:32 PM
mopar2ya
Nov 28, 2004 06:42 AM
