Head porting and ceramic coating
Old Oct 11, 2004 | 07:34 PM
mopar2ya's Avatar
Im looking for a volunteer who has a good working knowledge and experience that is interested in sending us a head, manifold and turbine housing for porting and coating.
I will do this free of charge with the condition the he has recent dyno sheet and is willing to dyno the truck afterwards.
Weve done quite a bit with dodge turbo cars with good results, and are branching into the diesel market.
I can only do one, so if you have a good deal of experience and the ability to dyno before and after results let me know.
If your not the one who gets the complimentary work, we can still get you a quote.
thanks,
wallace
Old Oct 12, 2004 | 02:23 PM
mhuppertz's Avatar
Did you get a volunteer yet?
Old Oct 13, 2004 | 01:53 PM
fearthedeere's Avatar
About how much will it cost to do this? id like to get it done when i repaint my truck. i just dont know when that will be.
Old Oct 13, 2004 | 03:46 PM
TexasHardcore's Avatar
I don't see any benefits of coating a turbine housing (from a turbo builders standpoint). All I see is increased heat being retained inside the housing, resulting in premature turbo failure or damage.
Is there a good reason for coating a housing?
I'm not trying to bash the subject. I know alot of people who have their housings coated, among other parts. But I'm just wondering if I'm right, or if there's a good reason for doing it other than looks...?
Old Oct 13, 2004 | 05:39 PM
Heat is the energy that drives the turbo. The more heat you can retain in the manifold and turbine housing the more efficient the engine becomes.
Old Oct 15, 2004 | 03:49 PM
Alec's Avatar
Dave is correct. Turbo wrap that rascal and it will give you a couple more psi of manifold pressure.
Old Oct 15, 2004 | 06:41 PM
mopar2ya's Avatar
I did get a volunteer and should see his parts first of next month.
The head, manifold and turbine housing porting is 700.00 including the coatings. We coat the combustion chamber and exhaust ports, as well as a inner and outter coating on the manifold and a outer coating on the turbine housing.
Wannadiesel is exactly correct, heat is energy. Ill find a real informative article that goes into detail about the flow of exhaust vs the expansion/contraction of the gasses and how it effect things. On my turbo car swapped from a ported stock uncoated manifold which ran consistent 12.10s to a coated manifold, turbine housing and downpipe and ran consistent 11.70s, now other factors can account for part of the gain, but there was certainly an improvement.
I also dropped 200+ degrees of surface temp on the exhaust manifold, so it does work. The wrap does work, but traps moisture.
Old Oct 15, 2004 | 08:20 PM
Stomp's Avatar
Man I wish I read this sooner. I Just had everthing apart and it should be finished tomorrow. I going to need all I can get to make it to 500hp on number 2 and 600hp on some drugs.
The B.U.S.T. project is still a GO. It didnt survive round one. We will have to see if it survives round 2. It has some better parts now and it can hold the boost.
Stomp
Old Oct 16, 2004 | 07:11 AM
So now it's Project B.U.S.T.A., right? And if it's a success you can call phase 3 Project B.U.S.T.Y.A. Still working on a name for phase 4, by then you'll have titanium connecting rods, a billet crank, and the head will be welded on.
Old Oct 16, 2004 | 09:27 AM
Stomp's Avatar
I hope it holds for a while. I would like to get it painted. I'll never get it painted if I keep puting money in the motor. Oh well who cares I may have a junk yard dog, but its fast. Plus paint doesnt make it go faster.
Stomp
Old Oct 16, 2004 | 10:46 AM
Redleg's Avatar
If you paint it, you'll be losing the pucker factor and people will be parking closer to you than you may like.
Old Oct 16, 2004 | 02:28 PM
Stomp's Avatar
LOL Yeah your right. The problem is its starting to rust living along the coast. I need to do something pretty soon.
Stomp
Old Nov 27, 2004 | 04:19 AM
12valve@heart's Avatar
Any update on your tests yet?
Old Nov 28, 2004 | 06:42 AM
frostie's Avatar
So, I wonder what the other factors are.
4/10s of a second is a lot I would be interested in getting that much more HP from a little bit of coating. I know porting does a lot but coating Im not sure about.
Frosty
upersleder
Mar 19, 2007 02:03 PM
Pride & Joy
Jan 18, 2007 11:44 PM
Lurch519
17
Jun 27, 2005 01:41 AM
