Plastic air dam under front bumper
Old Feb 5, 2011 | 02:26 PM
sinawalli's Avatar
Some Edit backed into my truck, and split. It wrecked the plastic air dam under the front bumper. What does it do? Can I just remove it and go without? Thanks!!
Last edited by madhat; Feb 5, 2011 at 04:27 PM. Reason: Language... that was a new one...nice
Old Feb 5, 2011 | 04:02 PM
Brian Lent's Avatar
Yeah it's fine without it, I have a blizzard plow and haven't had an airdam for 4 years since I had to take it off for the bracket.
Old Feb 5, 2011 | 04:28 PM
madhat's Avatar
Administrator/Jarhead
You're fine with out it, but it will help a little with fuel mileage. It does not hurt the truck any.
Old Feb 5, 2011 | 06:14 PM
sinawalli's Avatar
Thank you!!
Old Feb 6, 2011 | 06:33 AM
Dodgezilla's Avatar
I drove for a while without it and I think the truck looks strange without it. If your front end is rusty, like many are, it really looks bad. I found a cheap replacement on E-Bay and am happy I did.....
Old Feb 6, 2011 | 08:15 AM
sinawalli's Avatar
What did you use as search words on Ebay? Tried a few things, to no avail. Thanks!!
Old Feb 6, 2011 | 08:19 AM
MikeyB's Avatar
Busted mine years ago. Didn't see a change in fuel economy or engine cooling with the air dam removed.
MikeyB
Old Feb 6, 2011 | 08:55 AM
OldDodgeOwner's Avatar
You can get a new one from LMC Truck for $90.
I thought about replacing mine, but I figured with the places I go with my truck it'll probably just get ripped off again anyhow, so I never put one on.
Old Feb 6, 2011 | 02:55 PM
Dodgezilla's Avatar
Dodge Ram Air Dam
http://cgi.ebay.com/ebaymotors/OEM-N...item4cf4ffcabc
Old Feb 7, 2011 | 04:13 PM
sinawalli's Avatar
Thanks!!
Old Feb 7, 2011 | 04:45 PM
LeviMXUSMC's Avatar
I havent had one on mine for the last year and every thing is just fine. I probibly would have drug it off by now any way.
Old Feb 7, 2011 | 09:40 PM
Rednax's Avatar
Front air dams that extend down to within 6" of ground -- and "block" the chassis components from air, so to speak -- are a proven way to increase fuel mileage. (I have measured quite a few trucks and found none lower; 7" was bout average; my2WD, stock, shows a 10" clearance.
If one has a lifted or "levelled" truck this benefit may be lost due to height of the overall body. It "may" be most effective with stock front rake.
I got old enough years ago that I stay with stock pieces like this. It isn't just cosmetic, the factory decided that there was a benefit to directing airflow, even if minimally.
Alfdude1
Jan 29, 2013 03:32 PM
eightball
Dec 23, 2006 10:12 PM
ViperSBT
Oct 23, 2003 08:00 AM
popeye
Feb 19, 2003 07:35 AM
