Pics of Opie's bypass and Mitusa Gusher(mac daddy pump)
Old May 3, 2009 | 10:39 PM
  #46
powermad's Avatar
wow when did the fuel pump come out? thats pretty cool! what kind of price for one of them?
Old May 4, 2009 | 04:25 AM
  #47
Bswope's Avatar
Opie has had this fuel sytem out for a long time, and was the ORIGINATOR of the first mechanical LP system, but has since went out on his own creating the Mitusa system!
If anyone want his # feel free to PM me and Ill give it to ya!!
He is a great guy and his prices on the systems are great! Cheaper than the Airdog/Fass systems!!!!!!!!! He also has kit to run these systems on the Dmax's.
Here is a link......http://www.opieparts.com
Old May 4, 2009 | 10:42 AM
  #48
D45's Avatar
D45
Originally Posted by madhat
Sweetness! That does look like an easy install.
Yes, I was thinking about this kit but had no idea how hard/easy the install would be......looks like it can be installed in under an hour and is very easy
Old May 4, 2009 | 11:12 AM
  #49
Bswope's Avatar
Heck I was messing around and took me 1/2 hour tops! VERY easy install!!!!!
Old May 4, 2009 | 11:47 AM
  #50
xtoyz17's Avatar
Which install? The pump or the bypass?
Old May 4, 2009 | 11:59 AM
  #51
xtoyz17's Avatar
Originally Posted by rufushusky
You could run the Glacier big line kit with the filter head. There you just replace the fittings on the cp3 and the bottom of the fuel bowl.
http://www.glacierdieselpower.com/pr...id=MK20306-BLK
The Cat filter will work on that head. The fleetguard filter they have in the kit is NOT really a 2 micron, it is really 5 microns.
Their regular one might not be so bad, but the remote mount is the one I'd need with my intake elbow. 120 dollars for a few fittings, and a filter head and bracket made of sheet metal is a little pricey. I think I'd rather put one together myself instead.
Old May 4, 2009 | 12:02 PM
  #52
rufushusky's Avatar
Oh yeah I agree I made my own but the lines on FASS HPFP where easier to deal with than the stock lines. A baldwin fb1311, a pair of o-ring -10 to -6an and -6 pushlocks and your in business.
Old May 4, 2009 | 12:52 PM
  #53
Bswope's Avatar
Bypass....
Old May 4, 2009 | 08:07 PM
  #54
Bswope's Avatar
Originally Posted by Ace
Id still like to know what exactlly this setup is doing as far as bypassing anything? Just asking......
Old May 5, 2009 | 06:46 AM
  #55
Ace's Avatar
Ace
It bypasses through a filter back to the heater return like the Cummins kit, but with the added value of coolant filtering. I believe It's cheaper AND better than a $500 regulator that Opie himself doesn't seem to be able to explain, at least to my satisfaction.
Old May 5, 2009 | 07:38 AM
  #56
Jason_K's Avatar
hey buddy,
those sure are some pretty toys you got there. i bet you can't wait for spring fling to find out how everything works together.
Old May 5, 2009 | 07:11 PM
  #57
12valve's Avatar
is that a true 2 um filter?
Old May 6, 2009 | 08:23 AM
  #58
AH64ID's Avatar
which filter?
Old May 8, 2009 | 10:38 PM
  #59
cminzey's Avatar
opie's bypass
Hey where did you get the bypass setup I haven't been able to find a website
chuck
Old May 8, 2009 | 11:51 PM
  #60
biodiesel CTD's Avatar
chuck
Here's the website: http://www.opieparts.com
If I knew for sure that Opie's fuel pump was as good as the airdog, then I would be sold. I like the fact that if it fails, then you would still have the factory pump. If the airdog fails, then you are screwed. I just don't understand why more people aren't running the opie fuel pump if it's so good. So far it looks like a better system.
